1990 2.5 I broke my crankshaft into two pieces. - JeepForum.com
post #1 of 2 Old 03-13-2009, 11:59 PM Thread Starter
sbmf66
I have the engine torn down to the bare block, and found that I have one more problem. The engine/transmission alignment pin (I named it myself) is mangled on one side it needs to be pulled out and replaced before I bolt the tranny back up. Where can I find these? Should I go to a junkyard? Has anyone seen this before? Is it possible that engine/ tranny misalignment is what caused my crank to break?
sbmf66 is offline
post #2 of 2 Old 03-14-2009, 01:16 AM
1C41N0
What you're probably talking about is in the bell housing there is a"dowel pin It might also be in the back of the engine block (either or). I would probably check your local junkyard. I'm not sure of any stores that sell replacements. If I find one I'll let yah know.
1C41N0 is offline
transfer case broke into pieces!!! aviles TJ Wrangler Technical Forum 2 10-14-2009 09:01 PM
1990 xj 4.0 into 1990 yj finishing where someone left off moparcory617 YJ Wrangler Technical Forum 4 10-11-2009 02:41 PM
Broke bolt head, then broke the extractor! HELP!!! EugeneTheTJ TJ Wrangler Technical Forum 11 08-22-2009 08:44 AM
my 2.5l crankshaft damper broke jleal_21 YJ Wrangler Technical Forum 3 04-10-2009 07:45 PM
Are there 2 pieces to the tie rod? boozer1022 TJ Wrangler Technical Forum 3 07-20-2005 01:39 PM
