1989 yj worth it? - JeepForum.com
post #1 of 17 Old 06-25-2013, 09:00 PM Thread Starter
dunkeye11
Are the early YJs really as bad as people say? I have an chance to get one cheap but I don't want to really let my self down I wanted a 4.0 but it has a carbed 4.2 I just hope it has an ax-15 and not that French one
Are there any big things I should look for biggest fear is it was a project it's in parts and does not run
dunkeye11 is offline
post #2 of 17 Old 06-25-2013, 09:11 PM
AmmitOsiris
Get it and if not your cup of tea, part it out and make your money, if you don't need smog the 4.2 is a great engine
AmmitOsiris is offline
post #3 of 17 Old 06-25-2013, 09:22 PM Thread Starter
dunkeye11
Is it easy to replace the carter carb?
post #4 of 17 Old 06-25-2013, 09:38 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
My 89 is my DD it has 209k miles and it runs just as good if not better then my 99 XJ .
The Peugot trans is not as bad as its made to be Mine shift fine it' crisp with no slop. The Carter carb works great and It has not had a nutter bypass and still has all the vacuum lines .
I say get it . You can replace stuff you dont like
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #5 of 17 Old 06-25-2013, 09:46 PM Thread Starter
dunkeye11
Ok just one last question
How hard do you guys think it will be to get it running
It has been siting for at least 5 years and I'm just going to assume with no prep work for storage
It's pretty much in pieces and it looks like the t case is unbolted for some reason
post #6 of 17 Old 06-25-2013, 10:09 PM
AmmitOsiris
Well mine was sitting for about 6 years and it started right up with only needing a fuel pump and new tank
post #7 of 17 Old 06-25-2013, 11:03 PM
Xpress
A tuneup NEVER hurts after that time, but they're pretty durable, should fire right up.
Worst case scenario, drop $1200 on a Howell TBI setup and enjoy one ridiculously great engine. $1200 ain't a whole lot in comparison to what you may be dropping into it in the future
All about that unibody life.
Xpress is offline
post #8 of 17 Old 06-26-2013, 12:27 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
My '88 sat for five years. We got it running after cleaning the carb. A rebuild was after that but it's all pretty easy.
Michaelgoesrawr is offline
post #9 of 17 Old 06-26-2013, 05:02 AM
vtmtnman
I've got an 89 YJ. I'm putting an mc 2100 on this weekend. The Carter was nothing but trouble for me, the worst of it being its habit of flooding on hills. Other than the Carter caused problems I love the thing.
vtmtnman is offline
post #10 of 17 Old 06-26-2013, 06:03 AM
roadyrob
1987 YJ Wrangler
nothing wrong with the early wranglers, the 4.2 is a great motor, especially if you like to modify. even the puggy trans lasts way longer than people think.
my question is about you, do you really want to take on a major project like this? do you have the skills or are willing to learn?
the jeep is a complete unknown. it may be as simple as flushing the carb and fuel system or it may need a complete rebuild.
the transfercase was disconnected for a reason, was it to replace u joints, replace clutch or is the tranny blown? there are people here that haven't driven their jeep for a year or two while doing a rebuild, are you up to it?
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #11 of 17 Old 06-26-2013, 07:54 AM Thread Starter
dunkeye11
Thank you for asking that
Upon closer inspection of the photos I took it looks to had been started a conversion to fuel injection or completed
Another complete unknown
Something that did not help was my friends dad (the actual owner who bought and did the work) wasn't there and my Freind had no idea anything that was wrong or working on it
I'm going back on Sunday or Monday with another Freind who is a good mechanic and check it out again and see if we can put it back together a bit and try to get it going
What size do photos have to be
I can't seem to post any and it would be a huge help
post #12 of 17 Old 06-26-2013, 10:43 AM
dcocch
Upload pictures to photobucket and then copy and past the IMG code here, it's way easier.
dcocch is offline
post #13 of 17 Old 06-26-2013, 11:25 AM
Old4X
1990 CJ7
The Carter BBD is not as bad as many here would have you believe.
Any carb with 200,000 miles on it is in dire need of complete overhaul, not just some gaskets and a spray bomb of solvent.
Millions of them were sold and they powered American trucks billions of miles.l Mine was completely reworked 4 years ago, it has over 200,000 miles on it and is super reliable, better gas mileage than any 4.0 posted here that I have seen.
What ever you do, get it running in OEM condition first before you go scabbing after market parts on it. Otherwise you will not know if there is an underlying mechanical problem or just a mis-match of specs causing poor performance.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #14 of 17 Old 06-26-2013, 11:59 AM
Tom95YJ
Tom95YJ's Avatar
Great post
Sent from AutoGuide.com App
'99 XJ Black Betty
Tom95YJ is offline
post #15 of 17 Old 06-26-2013, 01:39 PM
piotrsko
Dude: it's a YJ. It will start and run. Maybe not well......but that would be a whole nother story. That is why we use this forum. If its good and cheap and you want a project then buy it. YKYDAYJ when:
piotrsko is offline
