1989 YJ-TPI 383 swap - JeepForum.com
post #1 of 10 Old 05-15-2010, 01:40 PM Thread Starter
stoker18
Hey guys. I have a question for all of the engine swap experts. I'm putting a TPI 383 in my 1989 wrangler. As far as the fuel pump goes, what is my best option? I've read about Grand Cherokee in tank pumps and Corvette in tank pumps and external pumps. There is honestly so much info on this site that I could spend a week reading about the projuects people do! Does anyone have an opinion on what my "best option" is? Any and all help is greatly appreciated.
-Stoker
stoker18 is offline
post #2 of 10 Old 05-15-2010, 06:53 PM
wanabejeeper
1987 YJ Wrangler
most guys who dont have an in tank pump to start with just plumb in an external pump and filter and regulator. Be sure to replace the line with hose that will handle the pressure
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #3 of 10 Old 05-15-2010, 07:15 PM
dodger889
What pressure are you needing? if it is at about 45psi then a stock wrangler pump will work.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #4 of 10 Old 05-16-2010, 10:16 AM Thread Starter
stoker18
A stock Wrangler pump from what year? My '89 was a carb'd engine w/ mechanical pump on the block.
I would really like to get an in-tank pump to help keep the pump cool. If I can't figure out which in-tank pump will work, I will go with an external pump though.
stoker18 is offline
post #5 of 10 Old 05-16-2010, 12:54 PM
dodger889
Do you have the 20 gal tank? with the rectangle opening in the top of the tank? then look for one from a 91-95 yj.
post #6 of 10 Old 05-16-2010, 03:36 PM Thread Starter
stoker18
Yes, it is the 20 gal tank with rectangle opening. I was told that the fuel injected YJ fuel pump won't put out the volume I need. But, who knows if the guy I heard that from knows what he is talking about. I know that I saw a thread somewhere on this forum about a Corvette pump working well with minor modification. Anyone know anything about that?
stoker18 is offline
post #7 of 10 Old 05-16-2010, 07:11 PM
dodger889
How many gals/hr flow are you looking for?
post #8 of 10 Old 05-16-2010, 08:00 PM Thread Starter
stoker18
For a stock TPI 350 the fuel pump is rated at around 40gph at 47psi. Can an injected YJ pump put that out? I noticed that GenRight has a fuel module that bolts in, but they say it is only good for up to 5.9L engines.
stoker18 is offline
post #9 of 10 Old 05-16-2010, 08:12 PM
Bastidjeep
See if you can fab up using a Walbro 255 lph pump in tank. The make them for the 5.0 mustangs and are dirt cheap. That will be more than all the fuel requirements you will ever need.
Bastidjeep is offline
post #10 of 10 Old 05-16-2010, 08:43 PM Thread Starter
stoker18
I'll look into the Walbro. Thanks for the info guys.
stoker18 is offline
1989 YJ Engine Swap pkearney06 YJ Wrangler Technical Forum 1 03-23-2010 12:29 PM
Any words of wisdom for a 1989 Wagoneer D44 swap into TJ Oregun TJ Wrangler Technical Forum 12 04-13-2009 08:50 AM
1989 Yj bryris YJ Wrangler Technical Forum 10 02-22-2006 10:52 PM
1989 4.0l JDREDNECK YJ Wrangler Technical Forum 14 09-30-2005 08:01 AM
engine swap 1989 4.2 carb'd to newer 4.0 fuel inj. mxfig YJ Wrangler Technical Forum 3 12-06-2002 01:11 AM
