1989 YJ Starting Issue? Electrical? - JeepForum.com
post #1 of 2 Old 08-26-2011, 12:53 PM Thread Starter
yabo71
Ok. It a 1989 2.5 5 speed yj. Until last friday it ran fine. I had Tuffy do some welding on the exhaust and every since it will not run. They replaced the computer. Then the fuel pump was not working. I put the new fuel pump in and it now pumps fuel. Only problem it still will not run. As for the electrical now when I touch the brake pedal the hazard lights, radio and gauges go haywire, Also when I turn the headlights on the hazard lights, radio and gauges also go haywire and the headlights them selves do not come on. Any help? Things to check?
yabo71 is offline
post #2 of 2 Old 08-27-2011, 05:24 AM
Mark05059
check all the grounds.. and clean them.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
1989 YJ Islander with 289 conversion electrical issue alpinevend YJ Wrangler Technical Forum 7 08-09-2011 02:59 PM
1989 yj 2.5 starting issue rzrefi09 YJ Wrangler Technical Forum 3 05-03-2011 02:02 PM
starting/electrical issue??? need help twizz TJ Wrangler Technical Forum 1 05-24-2010 06:27 PM
1989 4.2 Starting blue89wrangler YJ Wrangler Technical Forum 18 01-06-2009 11:28 AM
YJ starting issue (perhaps electrical) Inch7706 YJ Wrangler Technical Forum 1 09-06-2008 05:33 PM
