1989 YJ alternator Question - JeepForum.com
post #1 of 6 Old 08-23-2014, 05:07 PM Thread Starter
TippmannA-5
So I just completed a HEI conversion because I could not figure out why my old system was not giving spark. But now that the jeep is running I dont think my alternator is charging. I was just wondering does the icm need to be in place for the alternator to charge or can I rip that out. There is also a diode on the white wire out of the alternator that looks like it started to melt. Any way any electrical gurus would be much appreciated!
I'm growing rather fond of driving a vehicle with the aerodynamic qualities of a brick.
Yellow Jeep Club Member #4.2
Every time a bird craps on my jeep, I sit on my front porch and eat scrambled eggs to show them what i'm capable of!
TippmannA-5 is offline
post #2 of 6 Old 08-23-2014, 08:39 PM
Que89YJ
The diode was to stop the alternator from backfeeding the coil and keeping the coil powered after the ignition was off. The alternator is self regulating so as long as the 12 volts is supplied to the control side your alternator should be supplying power.
Que89YJ is offline
post #3 of 6 Old 08-24-2014, 08:31 AM
mike134
You can check if that diode wire is working properly. It doesnt exactly look like a professional job. Are those solder joints on the ends?
mike134 is offline
post #4 of 6 Old 08-24-2014, 10:16 AM
bpounds
bpounds's Avatar
Hate to disagree with the experts here, but I don't think there is any diode in the charging system.
There is supposed to be a "resistance wire - 15 ohms". It connects between the tan wire on the alt and the yellow wire that connects to the ignition switch and the dash gauge.
I'm looking a the schematic, for a 4.2L, and I don't see any diode in the wiring. All the diodes are internal to the alt.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #5 of 6 Old 08-24-2014, 11:58 AM
Que89YJ
The diode isn't in the schematic.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #6 of 6 Old 08-24-2014, 12:23 PM
born2fish
if you search the team rush upgrade, it will explain the need for the diode
born2fish is offline
