1989 yj 2.5 engine wont start or run - JeepForum.com
post #1 of 13 Old 10-28-2013, 05:27 PM Thread Starter
TMSquy
The jeep sat for awhile and I have worked around it for awhile. Here and there I tried diagnosing the problem. The injectors spraying fuel and it has spark. Timing chain was replaced recently and cylinder 1 at tdc has both valves shut. Distributor was recently replaced. The problem I'm having is fuel mixture isn't entering the combustion chamber. I tried pouring large quantities of gasoline into the intake manifold, crank it a few times, still no fuel to plugs. Anyone has any experience why? I tried replacing the egr valve and made no differrence. I unbolted to downpipe thinking a clogged exhaust isn't allowing flow, still no mixture to combustion chamber.
TMSquy is offline
post #2 of 13 Old 10-28-2013, 05:31 PM
Que89YJ
The only way fuel can't get to the plugs if you are pouring fuel into the throttle body with the butterfly open is if something is blocking the throttle body.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #3 of 13 Old 10-28-2013, 05:44 PM Thread Starter
TMSquy
Even if butterfly is open it doesn't help.
TMSquy is offline
post #4 of 13 Old 10-28-2013, 07:19 PM
Que89YJ
How are you telling it fuel is getting to the cylinder?
Fault codes:
No Start:
Que89YJ is offline
post #5 of 13 Old 10-28-2013, 08:42 PM Thread Starter
TMSquy
Mixture isnt getting to the combustion chamber. Plugs bone dry. Spray either in the plug holes it attempts to fire.
TMSquy is offline
post #6 of 13 Old 10-28-2013, 09:14 PM
Que89YJ
Then you need to pull the manifold and see where it's blocked. Something has nested in there while it was setting for such a long time. There it's no other reason for something from the throttle body not to get into the cylinder through the intake.
Fault codes:
No Start:
Que89YJ is offline
post #7 of 13 Old 10-28-2013, 11:55 PM Thread Starter
TMSquy
That's only option. Otherwise I would say the valves aren't seating
TMSquy is offline
post #8 of 13 Old 10-29-2013, 06:53 AM
Que89YJ
The valves not opening.
Que89YJ is offline
post #9 of 13 Old 10-30-2013, 12:00 AM Thread Starter
TMSquy
I wonder why. I might pull the valve cover and see if I can find anything going on with the valvetrain
TMSquy is offline
post #10 of 13 Old 10-30-2013, 08:09 AM
Que89YJ
Yes, if the valves are working then you need to pull the intake. Chances are that something set up house in the intake while it was setting.....maybe the exhaust too. Could be blocked stopping you from pushing any air.
Fault codes:
No Start:
Que89YJ is offline
post #11 of 13 Old 10-30-2013, 01:41 PM
Siva283
Wouldnt a compression test be a good idea? With the exception of bone dry spark plugs this sounds very similar to the issue I was having. If exhaust or intake is blocked wouldnt that mess up compression as well. Definitly easier than pulling the manifolds.
Ask me how I know...
Siva283 is offline
post #12 of 13 Old 10-30-2013, 02:34 PM
Que89YJ
Compression test and a bleed down test. I don't know how anything can get past the throttle plate. The more I think about it. Run the compression test. The bleed down kit should come with it. I would be real curious if something nested in the exhaust and its totally plugged. With the bleed down test it comes with a connector to put air in the cylinder. I would crack up the air pressure and see what comes out of the exhaust. Or have someone turn it over and stand at the tailpipe and see how much air is being pushed out.
Fault codes:
No Start:
Que89YJ is offline
post #13 of 13 Old 11-03-2013, 01:03 AM Thread Starter
TMSquy
Like I said, I unbolted the downpipe to see if something blocked the exhaust. Its on open manifold at the moment. Compression reads roughly 115 each cylinder. Tommorrow ill unholy the valve cover and see if the rockers are pushing the valves properly. That and or if something happened to the pushrods. The compression is a bit low, but not low enough to say it shouldn't run.
TMSquy is offline
