1989 wrangler brake system - JeepForum.com
post #1 of 4 Old 03-03-2004, 05:09 PM Thread Starter
walkman
hey guys have problems with spongy brakes. Ihave replaced all of the lines, the wheel cylinders, calipers and master cylinder. I have bled the brakes 6 times. Also when i start the engine the brake pedal travels all the way to the floor with no resistance. Can you help please
walkman is offline
post #2 of 4 Old 03-03-2004, 05:42 PM
Scurv
Scurv's Avatar
Sounds like there's air in the master or it's bad?? Chec the vac assist to make sure it's not leaking air and the master cyl mounting nuts for tightness?? Looking in the Hayens it says: Could be a clogged resevoir vent hole, defective check valve, or proportioning valve. Any fluid leaking anywhere???
RETIRED USAF MEDIC
89 YJ, 258 I6, 5 Speed/Manual, Red, 30x9.50 GSA/Gambler,Air Force Jeep Club Member #31
Red Jeep Club Member #284
Scurv is offline
post #3 of 4 Old 03-03-2004, 06:14 PM
*Jeremy*
Yeah sounds like the vacuum assist booster is leaking.You can undo and plug the vacuum hose to it and see if your brakes feel tighter,it will be like having manual brakes so it will be a little harder to stop but that should tell if the booster is the problem.I have had mine like this for a while now and Im so use to it I dont know if I will even bother buying a new booster,its also a good way to keep my wife from driving it,she refuses
*Jeremy* is offline
post #4 of 4 Old 03-04-2004, 06:19 PM
Scurv
Scurv's Avatar
find anything loose???
RETIRED USAF MEDIC
Scurv is offline
1989 Wrangler Valleycat YJ Wrangler Technical Forum 3 02-08-2010 02:16 AM
1989 Wrangler YJ BJIM YJ Wrangler Technical Forum 5 05-04-2009 03:34 AM
1989 wrangler CT98XJ Wrangler General Discussion 2 03-29-2009 09:33 PM
Will a 1989 Wrangler Full steel door/hard top fit on a 1995 Wrangler alandchris YJ Wrangler Technical Forum 2 03-13-2007 04:51 PM
1989 Wrangler VS 1992 Wrangler HELP Danbo56 YJ Wrangler Technical Forum 23 01-19-2006 04:58 AM
