1989 Jeep Yj cranks but no spark. - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1989 Jeep Yj cranks but no spark.
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 06-11-2012, 07:40 PM   #31
Old4X
1990 CJ7
Really need to know the fuel pressure the TB is seeing. A clogged return line will raisee pressure to the point of causing problems, as will low output pressure from the pump.
More elect. troubleshooting:
Take the coil snap connector off the top of the coil and check voltage to the "+" wire while the starter is turning. Must be battery voltage.
On the start relay, there is a ground wire. Temporarily hook a jumper wire from it to the battery "-" terminal. Put coil snap connector back on and try to start.
NOTE: Do Not leave the ignition switch in "on" position for any length of time. A few seconds is ok, time measured in minutes will fry the ICM (even a new one). So any tests on this circuit must be brief.
Carter BBD feeding 4.2 Nuttered 6 banger = 22 MPG Hwy
If it was easy, everyone would be doing it.
Old4X is offline   Reply With Quote
Unread 06-12-2012, 12:31 AM   #32
phnguyen7
all good now. it starts up and idles. I pretty much changed out the whole ignition but in the end i think it was a bad ground. Plus the engine was flooded which didnt help.
phnguyen7 is offline   Reply With Quote
Unread 06-12-2012, 12:36 AM   #33
phnguyen7
Thank old4x for your help! I think it was your magical ground that did it. And your advice about being flooded is a big one cause it started right up after that. now the jeep is running but a little rough on the low end. maybe the ecu has to reset?
