1989 Jeep Wrangler Value? - JeepForum.com
post #1 of 35 Old 05-16-2011, 04:44 PM Thread Starter
subliminal
1997 XJ Cherokee
I am looking at buying a 1989 Jeep Wrangler in fair condition with a 4.2 and manual transmission, Can someone tell me a rough estimate of what it is worth? Kelly blue book only goes back to like 1991. Thanks.
1997 Jeep Cherokee 4.0 Automatic NP231
subliminal is offline
post #2 of 35 Old 05-16-2011, 04:45 PM
schaef89
pics?
schaef89 is offline
post #3 of 35 Old 05-16-2011, 04:46 PM Thread Starter
subliminal
1997 XJ Cherokee
Dont have photos, it is in fair condition though, Body has some minor stuff wrong, interior looks very good.
post #4 of 35 Old 05-16-2011, 04:49 PM
schaef89
i'd say somewhere around 2500 if it's fair. 6cyl prices are a little higher but it's carb'd so you have to weigh that option in as well.
schaef89 is offline
post #5 of 35 Old 05-16-2011, 04:52 PM Thread Starter
subliminal
1997 XJ Cherokee
The guy is asking 1500 for it, he did say it needs a diode or something, he said without it the jeep will run a little rough at highway speeds. Anyone know what hes talking about? I know nothing about carb vehicles.
post #6 of 35 Old 05-16-2011, 04:56 PM
giggityjeeper
diode????
a 4.2 barely has ANY compter crap.... let alone any diodes....
sounds like it needs a new carb... which will be common for a 4.2 if it has the carter.. chekc the frame area around the shackles, check the body along the bottom of the door, lift the carpet if it has any, the floors may be rotted out.......
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #7 of 35 Old 05-16-2011, 05:00 PM
schaef89
I'd also check which tranny it has
schaef89 is offline
post #8 of 35 Old 05-16-2011, 05:19 PM Thread Starter
subliminal
1997 XJ Cherokee
Here are some cell phone photos, best I can do.
Uploaded with ImageShack.us
post #9 of 35 Old 05-16-2011, 05:23 PM
giggityjeeper
oh ya it will have a ax5 prolly... .expect to replace it as well
does look pretty clean tho....
for 1500 its prolly not a bad buy... expect to replace the carb, maybe the trans depending on what your doiong with it..
the 4.2 is a solid engine ONCE its running good, but that takes some patience and time and money...
be a good starter for sure
post #10 of 35 Old 05-16-2011, 05:27 PM
mylightsrsquare
should have the ba10 or the ax 15. if it was made after march 1989 it should have the ax15 but i might be wrong
1988 yj. 4.2l with a Weber and an ax15 swapped in
mylightsrsquare is offline
post #11 of 35 Old 05-16-2011, 06:55 PM
mudbug89
its a good deal as long as the frame is good.hurry up and buy it before i do lol.
mudbug89 is offline
post #12 of 35 Old 05-16-2011, 07:24 PM
cubewhiz
aww, it's so cute
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #13 of 35 Old 05-16-2011, 07:48 PM
icenikka
Bought an 89 a little over a month ago in Duncan BC Canada for 3000. Good/fair condition.
icenikka is offline
post #14 of 35 Old 05-16-2011, 07:53 PM
yellow2kgt
Like others have said. Check the frame for rust. Judging by the the pics it looks like it could be a good deal (assuming the frame is solid.) Considering it has a hard top and full doors you could part it out and get most of your money back. In my area the full doors would fetch $500 and the hard top would also fetch $500.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #15 of 35 Old 05-16-2011, 09:24 PM
timatoe
timatoe's Avatar
$1,500 is a very fair price, if it's not falling apart from rust.
timatoe is offline
Cover for an 1989 Jeep Wrangler sky84fire Wrangler General Discussion 3 08-05-2010 07:20 AM
1989 Jeep Wrangler LED Blinker Fix firedog348 YJ Wrangler Technical Forum 1 07-12-2010 08:39 PM
1989 Jeep Wrangler 2.5 computer RockHill YJ Wrangler Technical Forum 2 02-22-2010 11:17 PM
Cleaning up an old jeep, 1989 Wrangler Craig1319 YJ Wrangler Technical Forum 12 09-23-2008 09:36 AM
1989 jeep 2.5 rebuildkit for my wrangler link4889 YJ Wrangler Technical Forum 2 02-01-2008 09:49 AM
