1989 Jeep Wrangler ignition - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1989 Jeep Wrangler ignition
The Boss is away but Erin is here to STAY with a F.Y.S. SaThe Cure for your Tie Rod Roll!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-06-2012, 01:14 PM   #1
godzilla89
I have just purchased a 1989 Jeep Wrangler that has a 4 1/2 inch skyjacker lift with a 1 inch body lift with a swapped in 4.0L from a 1993 Grand Cherokee. The keys I was given are GM ignition keys, did the factory use GM ignition in that year or was that steering column swapped in by the previous owner as well?
godzilla89 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2012, 01:24 PM   #2
jason9
1990 TJ Wrangler
My 1990 has a GM door key and Chrysler ignition key.
jason9 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2012, 02:10 PM   #3
dancytron
The steering column is supposed to be the same as one used in an Chevy S-10. Could be they put a new lock or even a whole new steering column in it from an S-10.
BTW I have original keys and they both say Jeep on them.
dancytron is online now   Reply With Quote Quick reply to this message
Unread 03-06-2012, 03:07 PM   #4
MegaCabMan
J-E-E-P
Just Everyone Else's Parts
GM steering column, Ford Ignition System, AMC Engine, Chrysler Transmission.
It's the original column.
BTW My '68 Commando had the buick dauntless V6, original from the factory!
They call me the King of Fun! Everwhere I go I hear "Here comes that Fun King MegaCabMan"
MegaCabMan is offline   Reply With Quote Quick reply to this message
