1988 YJ transfer case - JeepForum.com
post #1 of 15 Old 08-31-2011, 09:38 PM Thread Starter
bikermwtp
Hi folks, im new to tall this forum stuff and jeeps. Here is my issue. I have a 1988 Jeep YJ 4.2L 5 speed. The transfer cas got busted my previous owner, so i found one on kijiji to replace it with. It has all the same numbers marks ect other than serial number is diff, But the input shaft on the new one i have is an 1/8" smaller than the orignal one that came off it. Does anyone know why this is? its off the exact same jeep i seen it. Im stuck with this one now and not sure what to do. Im looking for info and or how to tell things apart, any help would be greatly appreciated i know very little about jeeps. Thanks for your time!
bikermwtp is offline
post #2 of 15 Old 09-01-2011, 12:22 AM
Fin_Reaper
What do you mean 1/8" smaller? OD, ID, Length? What is the spline count? If you still have the BA-10/5, your TC input shaft should be 21 spline.
88 YJ with stuff
Fin_Reaper is offline
post #3 of 15 Old 09-01-2011, 07:28 AM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
I think he had a NP207 and bought a NP231. there should be a tag. read it and post up what it says or just take a pic of it and post up.
Thomas
-1987 YJ
Tompatt is offline
post #4 of 15 Old 09-01-2011, 07:34 AM
Fin_Reaper
My 88 4.2/BA came with the 231 stock. 87 was the oddball year for TC's.
88 YJ with stuff
post #5 of 15 Old 09-01-2011, 08:29 AM Thread Starter
bikermwtp
They are both NP231's Bit the input shaft that slides onto the tranny on the new tc is 1/8" smaller inside diameter. ill take pics and post them later.
post #6 of 15 Old 09-01-2011, 08:57 AM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
ooops. haha mb forgot about it. it may be from a different year? I know there are some np231s that are 21 spline but the input shaft comes in different sizes. but its just a guess.
Thomas
-1987 YJ
Tompatt is offline
post #7 of 15 Old 09-01-2011, 09:32 AM
Fin_Reaper
Count ye splines.
88 YJ with stuff
post #8 of 15 Old 09-01-2011, 12:45 PM Thread Starter
bikermwtp
so it took me 20 mins but i did a count of splines one is 22 and one is 23 so thats the problem, ive been looking all over the map and cant find any tcases for this thing, would i be better off to change the input shaft n gear?
post #9 of 15 Old 09-01-2011, 02:31 PM
Fin_Reaper
I've never seen a 22 spline. My guess would be that it's a 21. Swapping an input shaft isn't tough in the 231's.
88 YJ with stuff
post #10 of 15 Old 09-01-2011, 11:06 PM Thread Starter
bikermwtp
whats a new shaft worth roughly? and how long would you say it would take for the average person to do it?
post #11 of 15 Old 09-02-2011, 10:26 AM Thread Starter
bikermwtp
Is there much diffrence between the 21? like is the 23 spline a whole lot stronger? the guy that sold me this 21 spline said i could trade him trannys is there any advantage from the 21 to the 23 spline?
post #12 of 15 Old 09-02-2011, 01:55 PM
yotefever
1987 YJ Wrangler
I am going through this right now because I am getting rid of my ba10.
I picked up an AX15 with an NP231 out of a '93 YJ up in Minn.
It turns out it has a 21 spline input shaft.
I got some replies here on JF and traded shafts with one member but it won't go into my planetary gears???? It appears the od of the shaft, not including the teeth on the outside is more than what my old 21 shaft was???
I also got another shaft with the pg's but it is about 1/2 longer and that shaft will fit my pg's but don't know if there will be a problem using it with the longer length.
You should be able to swap yours out if they are both 231's I am not familiar with the 207.
Here is some youtube on the reassembly
There are 4 of them and they are very detailed. I believe there is a disassembly vid too.
I don't think one is stronger than the other but the 23 spline is the newer and more common setup you will find.
And welcome to JF and Jeeps! You will get your questions answered here, I am new to jeeps too and it has been a great help, even if it empties my wallet.
Sent from my home computer
yotefever is offline
post #13 of 15 Old 09-09-2011, 05:46 PM Thread Starter
bikermwtp
Ok so im ready to pull my hair out and scarp this thing..... I keep getting so many diffrent awnsers. what i want to know i have the stock 23 spline output shaft on the tranny now. now the input from the crank side would it be the same as a 21 spline output tranny? if you know what i mean? my head is throbbing from this thing.... any help would be grat guys thanks
post #14 of 15 Old 09-09-2011, 05:50 PM Thread Starter
bikermwtp
Basicly can i take the tranny thats on there now (with the 23 spline output shaft) and switch it with a new 21 spline tranny? are the inputs of the 2 trannys the same?
post #15 of 15 Old 09-09-2011, 09:57 PM
yotefever
1987 YJ Wrangler
I am no expert and always learning something new every time I work on it but as far as I know the ax15 have the larger input shaft but my ba10 has a narrower diameter.
You should probably pm Mean Max on here, he has been a wealth of information for things I have worked on and things I'm still planning on doing.
transfer case. t-case
LOUD violent POP from transfer case on occasion from my lifted Rubicon transfer case anymanusa TJ Wrangler Technical Forum 14 07-23-2010 04:54 PM
Did 1988 YJ come with 231 transfer case? JOExFROMxNY YJ Wrangler Technical Forum 2 12-30-2009 09:51 AM
Transfer case boot for 231c transfer case in jeep wrangler kniteman YJ Wrangler Technical Forum 2 03-16-2009 01:28 PM
1988 231 transfer case jumps out of gear mcmunsell YJ Wrangler Technical Forum 11 08-06-2008 06:41 PM
1988 NP231 Transfer case RoooNick YJ Wrangler Technical Forum 2 07-15-2006 07:24 PM
