1988 jeep yj switch over - JeepForum.com
post #1 of 4 Old 08-12-2013, 08:47 PM Thread Starter
Wsigalet95
1988 TJ Wrangler
i have a 1988 jeep yj pretty much stock, i am looking at a 1984 cj7 that has a 4 inch suspension lift and 33 inch tires and hardtop and all that kind of stuff. would the cj7 parts work with my 1988 jeep yj if i wanted to put them together?
Thanks
Wsigalet95 is offline
post #2 of 4 Old 08-12-2013, 08:53 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Nope. Not a desirable hybrid.
Luck Favours The Prepared
Anticanman is offline
post #3 of 4 Old 08-12-2013, 09:04 PM Thread Starter
Wsigalet95
1988 TJ Wrangler
would putting my motor from my 88 into it be worth it or are the cj7s very good? the cj7 is in better shape then my 88 as of the body/rust but it does not run.
post #4 of 4 Old 08-13-2013, 07:09 AM
superj
if the cj is in better shape, body and rust wise, i would swap the motor over. its the same motor so it should be easy if you have the 6 cylinder in both of them.
otherwise, the rear springs will change, the hardtop and doors, and the tires can be mounted on your yj rims. cj and yj have different bolt patterns on the rims and cjs have thinner front springs then yjs do.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
