1988 jeep yj cant shift into 4wd - JeepForum.com
post #1 of 9 Old 11-03-2013, 01:33 PM Thread Starter
Wsigalet95
1988 TJ Wrangler
i cant get my jeep to shift into 4wd. when i look under the jeep at the linkage while some one trys to move the shifter the linkage seems to get stopped or jammed. the shifter moves and then stops about a inch before it usually goes when shifting into 4wd like its hitting a wall or something. where could i start to look to resolve this problem?
Thanks
Wsigalet95 is offline
post #2 of 9 Old 11-03-2013, 01:46 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
To me it sounds like it is binding up. Liberally soak all of the the linkages with PB blaster, or Kroil and let it work in for a hour or so. Also unbolt the inner and outter shift boots to ensure they are not jamming it up. Sometimes I need to have my XJ rolling forward a little to get my shifter for 4wd to engage or disengage
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 9 Old 11-04-2013, 06:01 AM
irnmadn88
Sounds like the linkage has slipped. There is an adjustment procedure.
http://www.jeepforum.com/forum/f9/tr...stment-701221/
irnmadn88 is offline
post #4 of 9 Old 11-04-2013, 08:17 AM Thread Starter
Wsigalet95
1988 TJ Wrangler
Problem solved thanks for all the suggestions.
post #5 of 9 Old 11-04-2013, 08:25 AM
bpounds
bpounds's Avatar
Please share what was wrong and how you fixed it. That is how you pay it forward.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #6 of 9 Old 11-04-2013, 08:30 AM Thread Starter
Wsigalet95
1988 TJ Wrangler
Had some how lost the drain bolt on the Tcase not sure how. First time iv had to do the fluids not sure if it was put on tight from PO.
post #7 of 9 Old 11-04-2013, 08:31 AM Thread Starter
Wsigalet95
1988 TJ Wrangler
So a new bolt and filled the fluid I know there is going to be some damage to the Tcase but a replacement is not in the budget at the moment. On the plus side the Tcase works better then it ever has in the past for me but only owned the jeep for a short while.
post #8 of 9 Old 11-04-2013, 08:37 AM Thread Starter
Wsigalet95
1988 TJ Wrangler
Going to do tranny fluid change as soon as I can find a extension that I can grind down to fit the drain plug.
post #9 of 9 Old 11-04-2013, 08:43 AM
bpounds
bpounds's Avatar
A 5/16" allen wrench works well. Only needs a tiny bit of grinding.
Bill
bpounds is offline
