1988 jeep wrangler no heat - JeepForum.com
post #1 of 8 Old 12-12-2013, 01:33 PM Thread Starter
cg1588
Hi
I just noticed this morning that my jeep wasn't getting up to normal temp and the heat was blowing cold air. It usually only takes around 5-10 min to warm up but the whole ride to work it stayed cold and the temp gauge did not move (40min ride to work). I checked the antifreeze and it was full in the radiator and im not really sure where to go from there. Any ideas?
Christian
cg1588 is offline
post #2 of 8 Old 12-12-2013, 01:35 PM
Old4X
1990 CJ7
If burping the system doesn't work, put a new thermostat in it
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 8 Old 12-12-2013, 01:58 PM
baritone_mike
I would guess the thermostat went bad.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #4 of 8 Old 12-12-2013, 02:15 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Sounds like a Thermostat to me
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #5 of 8 Old 12-12-2013, 06:26 PM Thread Starter
cg1588
I burped the system and squeezed the hose coming off the top of the radiator a few times and it heated up like normal but when I stopped and turned it off for a few minutes it stopped working agian. Could the thermostat start working again and just stop? I'm going to pick one up tomorrow anyway to see if it helps.
cg1588 is offline
post #6 of 8 Old 12-12-2013, 06:31 PM
88GP
I had the same issue about a year ago and it turned out to be a thermostat. Other possibilities could be blockage in your heater core or vent control issues.
88gp
88GP is offline
post #7 of 8 Old 12-12-2013, 06:32 PM
Sparrows
They can get stuck. And for $4.00 its an easy and cheap thing to replace.
Cheers
June '13 YJOTM
Sparrows is offline
post #8 of 8 Old 12-13-2013, 11:30 AM Thread Starter
cg1588
New thermostat did the trick. Thanks for the help
cg1588 is offline
