1988 Ignition Control Module location??? - JeepForum.com
post #1 of 4 Old 09-04-2008, 10:28 AM Thread Starter
tj7695
Been having trouble starting since I bought my YJ, it will eventually turn over, but takes a lot of cranking to get there. I just replaced my second starter recently, have changed all the plugs, wires, distributor cap, new battery. The only things left are the coil and the ICM. I'm not the most mechanically inclined in the world, but the Chilton manual says the ICM is located on the fire wall adjacent to the battery, but I can't find it. Does anyone have a photo or suggestion where to look? I don't think the PO did the nutter by-pass, so it should be in there (I hope)!
tj7695 is offline
post #2 of 4 Old 09-04-2008, 11:45 AM
spshultz
1987 YJ Wrangler
On my '87 it is located below the washer fluid reservoir and coolant overflow tank.
It's #15 in this picture (although you can't see it).
http://home.sprynet.com/~dale02/engineba.htm
spshultz is offline
post #3 of 4 Old 09-04-2008, 12:13 PM
Solus
or if you have weird *** PO's then it will be zip tied to some random place
Solus is offline
post #4 of 4 Old 09-04-2008, 01:03 PM Thread Starter
tj7695
Thanks, I'll have to go take a look...and it's there! Thanks for the help!
tj7695 is offline
Electronic(ignition) control module location 87 yj square87 YJ Wrangler Technical Forum 2 10-08-2009 09:12 PM
Where is my ignition control module? parakleets YJ Wrangler Technical Forum 15 06-27-2007 10:17 PM
ignition control module rolledthatho YJ Wrangler Technical Forum 14 03-30-2006 11:48 PM
Ignition Module Location gustaia YJ Wrangler Technical Forum 4 12-11-2004 03:34 AM
where is my ignition control module rdarmstrong YJ Wrangler Technical Forum 5 12-23-2002 10:12 PM
