1987 YJ crank but no start - JeepForum.com
post #1 of 5 Old 06-07-2013, 10:49 AM Thread Starter
SHUVLHEAD
1987 YJ Wrangler
Driving down the road, jeep just shut off. Will crank with a weak spark. Not enough to start. Replaced the Coil, still weak spark.
Recently Nuttered, new Cap, Roter, wires and plugs.
Was running perfect since i nuttered it, maybe loading up alittle. Which i think it needs smaller jets in the refurb MC2100 carb i put on it.
Other than that, running great. Checked for loose wires/grounds and nothing.
Any help would be greatly appreciated.
SHUVLHEAD is offline
post #2 of 5 Old 06-07-2013, 11:07 AM
Prspallone
1982 CJ7
This could be many things. It's always a good idea to start by checking the batteries charge though. Could be something wrong with the fuel pump or lines, it's very possibly something with the carburetor though. While you wait for more people to respond take a quick search of old threads with similar issues, you probably will find your answer. Sorry I can't be of more help, but good luck, wacky stuff happens to my jeep all the time. Sometimes the problem takes care of it's self though!
Prspallone is offline
post #3 of 5 Old 06-07-2013, 11:41 AM
Old4X
1990 CJ7
Time for diagnostics.
Check compression
Check timing, timing mark vs. physical TDC on #1 piston.
Check for erratic timing esp abofe 1500 rpms.
Check vacuum reading, should be 21" MSL, adjust for your height above MSL.
Check vacuum needle at idle, should be steady or all but steady.
Pull spark plugs and "read " them for what is going on in combustion chamber.
Check timing chain for slack. Over 7 degrees, replace chain and both gears.
Check fuel pressure at carb with engine running.
Check for restricted exhaust
Did you add a dedicated ground to the black wire (3 wire harness) from the distributor?
Let us know what you find
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 5 Old 06-07-2013, 11:45 AM
Old4X
1990 CJ7
As you are nuttered, you can wire in a GM ICM in about 5 minutes to check if you have a bad ICM. Just the 2 nutter wires, a hot, a ground, and a wire to the neg post of the coil
Old4X is offline
post #5 of 5 Old 06-27-2013, 10:39 AM Thread Starter
SHUVLHEAD
1987 YJ Wrangler
Got tired of banging my head and took it MEAN MAX. New HEI ignition and the thing runs like a scalded ape.
