1987 Wrangler Speedometer Cable - JeepForum.com
post #1 of 4 Old 09-06-2012, 08:40 PM Thread Starter
Hacken
1987 YJ Wrangler
I would like to give a bit of info on the speedo cable for an 87 wrangler that can be hard to find because no one seemed to make one listed for that particular year. This can be found in other threads but I hoped to make it simpler to find.
Dorman makes the cable that can be used with the proper ends necessary for and 87 wrangler. The part # is 03269 and can be purchased through Advance Auto for about $25.00.
Hacken is offline
post #2 of 4 Old 09-07-2012, 06:03 AM
Nerfz
1987 YJ Wrangler
I would look at 87 wranglers and 86 cj7's to see if the part is the same for both...If it is the same you know your good...If not then I would double check your current cable to match it up if possible...
Because that is the one thing that stinks about 87's A lot of the parts were from the year before and the auto part stores have the wrong listings....
Nerfz is offline
post #3 of 4 Old 06-26-2013, 07:01 PM
tgnorwhal
1987 YJ Wrangler
is the end of the cable that connects to the T case supposed to be loose? was having issue of the speedometer working and then not. got down there wiggled it a little then tried hand-tightening the nut. seems to be working okay. just wondering if that connection can get loose and make the speedometer quit, or could it be a bad cable?
thanks
tgnorwhal is offline
post #4 of 4 Old 09-18-2013, 08:15 PM Thread Starter
Hacken
1987 YJ Wrangler
Im sorry i dont check this enough. No that cable should not be loose. Depending on how loose it was im sure that could have been your problem. the actual cable end is square and gets inserted into a small plastic gear that is run by the spinning tail shaft in the transfer case. the plastic gear is the one you would change if you were worried about oversize tires affecting your speedometer calibration.
Hacken is offline
1987 YJ Speedometer and Cable Question dsehl YJ Wrangler Technical Forum 25 03-04-2016 04:30 PM
Speedometer Gear Color/Tooth for 1987 YJ jhumphrey YJ Wrangler Technical Forum 7 03-10-2011 01:57 AM
Speedometer Cable YJ to CJ r7069c YJ Wrangler Technical Forum 6 01-22-2010 08:13 AM
speedometer cable help crb577 YJ Wrangler Technical Forum 1 07-29-2006 11:54 AM
Speedometer cable copscott76 YJ Wrangler Technical Forum 2 06-24-2005 06:31 AM
