Quantcast 1987 jeep yj rear disc brakes rear proportioning valve? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1987 jeep yj rear disc brakes rear proportioning valve?
Old 06-05-2009, 08:14 PM   #1
handyman48066
1987 YJ Wrangler
Just finished putting disc brakes on the rear of my 1987 jeep yj .Do I have to add proportioning valve to the rear brakes.Or just use the stock one up front.Right now its not stopping my 35's like i think they should.If I have to what will that do for me. Thanks Russ
handyman48066 is offline   Reply With Quote
Old 06-06-2009, 01:09 AM   #2
rumblebee1967
Not familiar with the jeep master cylinder yet, but in street rods an adjustable proportioning valve is usually a necessity and seems like the master cylinder is different (larger bore) on an all disc set up. The adjustable valve allows you to fine tune your stopping. Best way to determine if its right is to test it on a gravel road. see if it stops straight. The proportioning valve actually lowers the pressure to front I think but I may be backwards on that, its been a few years since I have installed one.
rumblebee1967 is offline   Reply With Quote
Old 06-06-2009, 07:47 AM   #3
boggerjeep
i used the stock one w'my 8.8 w' disc. my buddy got and ajustable and had to open full open said he waste his money??
sell your home. buy a Jeep and a shop. cost about the same to have.
boggerjeep is offline   Reply With Quote
Old 06-06-2009, 07:48 AM   #4
capone1680
There's alot of Good information out there on this subject. I would consider upgrading you Master cylinder.
Check here:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4DKUS_enUS287US287&q=Jeep+master+cylinder+upgrade
capone1680 is offline   Reply With Quote
Old 06-06-2009, 12:41 PM   #5
handyman48066
1987 YJ Wrangler
Thank You all for the info
Glock Forum
