1987 Jeep Wrangler - JeepForum.com
post #1 of 14 Old 01-02-2012, 07:17 PM Thread Starter
caseyhopkins12
1987 YJ Wrangler
1987 Jeep Wrangler
I have a problem... I am 17 years old and bought my dream jeep at an early age. The problem I am having is that my jeep is making this nasty noice when it is starting. It is not the starter, I have replaced it many times. Also the flex plate looks good, no broken teeth. I have no idea what the problem is and its driving me crazy. 87 Jeep YJ 4.2L Straight 6 automatic. HELP!!
caseyhopkins12 is offline
post #2 of 14 Old 01-02-2012, 07:20 PM
wannafixmyjeep
4.2 v6????
wannafixmyjeep is offline
post #3 of 14 Old 01-02-2012, 07:22 PM Thread Starter
caseyhopkins12
1987 YJ Wrangler
straight 6 sorry! haha
post #4 of 14 Old 01-02-2012, 07:50 PM
gunshw301
If I remember right mine had a shim between the starter and housing. Mine is a 2.5l so it might not apply. But if the teeth are mashing it would make a weird noise.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #5 of 14 Old 01-02-2012, 08:59 PM
superj
the 6 might have a shim also. my parts 6 came with a shim so maybe yours is missing it? my bmw made a horrible racket till i put that shim in on it so maybe that is your trouble
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #6 of 14 Old 01-02-2012, 10:03 PM
liftedyj91
X2 with the shim! it will stop the racket
liftedyj91 is offline
post #7 of 14 Old 01-03-2012, 04:59 AM Thread Starter
caseyhopkins12
1987 YJ Wrangler
i did put shims in... 1 some what thick washer on each side, brought it out about an 1/8 inch
post #8 of 14 Old 01-03-2012, 05:43 AM
roadyrob
1987 YJ Wrangler
no factory shims for the 87, they use the ford style starters like the CJ's. I have done quite a bit of reading on this as mine is loud too. changing starter brand from autozone to napa helped some but its still pretty loud.
there are quite a few different opinions on why some are loud and some aren't. some people claim to have fixed the problem with a new ring gear even though it didn't show wear, others claim its the thin plate between the bell housing and the tranny being warped and fixed it by putting a thin washer between the starter and plate on one side, depending on how the plate is warped it could be either bolt. while others claimed it is bad grounds or cables.
my plan is to live with it till I do a tranny upgrade then repace the ring gear and see if that helps. I sure get a lot of funny looks when I start it.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #9 of 14 Old 01-03-2012, 07:09 AM
Mark05059
what worked for one of my friends is we loosened the mounting bolts to the starter and while one of us pushed the starter up and towards the motor and one of us tightened the bolts up. Seemed to help it quite alot.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #10 of 14 Old 01-04-2012, 04:56 PM Thread Starter
caseyhopkins12
1987 YJ Wrangler
Whats weird is that the starting is getting worse. Almost to the point where it wont start. I pulled off the starter and the teeth were grinded down... a lot. Is it possible that the flex plate was installed backwards? or that the flex plate is loose? I bought a new flex plate a while ago because I thought that's what the problem was but it looks pretty good.
post #11 of 14 Old 01-04-2012, 06:33 PM
oldtime_ironman
I can't remember the details but there was a couple guys last year with a prob like this... turns out they had 2 different starters. The difference was, that one would only stick the gear out so far, and the other one would stick it way out. You can tell by looking at exactly how the gear chews - if its just on one edge, or on the "corner" of the teeth then you need the other starter that sticks it out farther.
Only other thing that it could be (I think) is something wrong with the flex plate. I've heard of them bending or cracking.
oldtime_ironman is offline
post #12 of 14 Old 01-04-2012, 07:23 PM
YJames90
YJames90's Avatar
I had this problem with the 4.3.
Heres some paragraphs from my swap
Back when I removed the 4.3 I broke the starter and had to replace it. THere was a problem installing the started from the get go like it didnt fit correctly.
Now when I turn the starter it makes a terrible binding noise againt the flywheel but turns the motor over.
Removed the starter and activated it to make sure its fully working correctly. It is.
Looking closer at the starter teeth they look to not match the teeth on the flywheel like they are too big.
This explaines why I cant get the starter to mesh in and bolt on the way it should.
Just the edges of the starter teeth have marks on them like they are pushing the flywheel just enough to turn the motor over.
Bought a 9 tooth starter but its redesigned and recomended by the auto parts store. It bolted up very easy but theres another problem.
I has zero function.
THe meter shows power going to the starter when the keys turned to run.
Im bring the starter to autozone to get it tested tomorrow. Just another roadblock
Woke up at 4:00 this morning to see if I could figure out the problem. I usually get up at 5. Bench tested the starter but this time tried the other small stud and it worked.
Installed the starter and the motor turns over nicel
My 2.5 to 4.3 swap thread
YJames90 is offline
post #13 of 14 Old 01-04-2012, 08:28 PM
zeus87gn
1987 YJ Wrangler
Folks,
I've been through this a couple of times.
The 87 4.2l takes a certain starter.
Problem is the 4cyl starter (my guess) can be mistaken for the 6cyl starter easily.
The Zoo (AutoZone) has had it mixed up for years.
I had the manager convinced, but thier corporate management wouldn't listen to her.
To tell the difference, look at the aluminum housing OD and compare it to the OD of the metal case of the starter drive. If they are the exact same size, it's the wrong one. If the alum housing is slightly larger in OD than the metal case, it's the right one. It is a noticible difference in size, but not really that much.
If you have the right starter and it's still grinding, it's not aligned correctly.
Another commented above on pushing it close to the block.
It's true. I've had to do it many tiimes with 2 different transmissions.
I've been able to figure out the 87 flywheel is specific, but that's for a clutch.
I don't know about the flexplate on an automatic.
HTH -
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #14 of 14 Old 01-04-2012, 08:38 PM
bharris68
So there is the bad news - if you shine a light in there, are the teeth on the flexplate ground down, too?
That could be a problem if the NOSE of the starter gear is worn out - shimming it would potentially cause that.
Shoot a picture of the teeth on the starter and I'll bet money that someone on here can look at it and tell you what you need to shim and where OR whether or not you've got the wrong (4 Cyl) starter
Enjoy!
bharris68 is offline
engine , flex plate , starter
1987 Jeep Wrangler NOOB usmcrecon YJ Wrangler Technical Forum 6 01-01-2012 07:56 PM
1987 jeep wrangler 4.2 TYS87YJ YJ Wrangler Technical Forum 9 11-17-2011 08:52 PM
1987 Jeep Wrangler YJ - $1900 in CT RatRide Wrangler General Discussion 4 02-09-2011 05:30 PM
304 v8 1978 into 1987 jeep wrangler dryfire1 YJ Wrangler Technical Forum 1 05-28-2009 08:35 PM
1987 Jeep Wrangler Engine Cutting Out tbmb27 YJ Wrangler Technical Forum 2 07-30-2006 08:32 PM
