19 gallon gas tank install help - JeepForum.com
post #1 of 5 Old 09-05-2011, 02:54 PM Thread Starter
cody11ca
Punctured my gas tank on my 93 yj 2.5L. bought a used 19 gallon gas tank from ebay for the same yr and size engine wrangler.
My issue is i can not for the life of me get the skid plate to bolt up. Did I buy a gas tank to big for my skid plate or am I doing something wrong.
THank You
93 yj, 2.5L, 33x12.5, 4inch lift, winch
Sacramento Jeepers Group #8
cody11ca is offline
post #2 of 5 Old 09-05-2011, 03:03 PM
tdewit
Did you do a dry fit?
1. Empty tank in hole?
2. Empty tank lying in skid plate with hoops tied down?
If 1 and 2 are OK, then realize it's a ***** to get back in. I did it with the body off, and it was difficult enough. Check the stickies, there's a installation guide for the fuel tank.
tdewit is offline
post #3 of 5 Old 09-05-2011, 04:21 PM
Jims-87YJ
1987 YJ Wrangler
Do both the old tank and the new one look the same physically? The tank should mount to the skid plate first and then the hole assembly will mount up into the frame. I put my tank in using a floor jack to lift it in place that helps quite a bit even if you have an extra set of hands.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #4 of 5 Old 09-05-2011, 09:27 PM Thread Starter
cody11ca
all look the same....what i did was get it up there, then loosen the straps and it slipped in. Thank you for your help, always appreciate the feed back on here.
cody11ca is offline
post #5 of 5 Old 09-05-2011, 10:02 PM
timatoe
timatoe's Avatar
Yeah, you're gonna want to drop the entire assembly then attach the tank to the skid with the straps etc. they lift the entire thing up.
timatoe is offline
Has anyone done the 15 gallon to 20 gallon gas tank mod? by modifing gas vent line? tybmw YJ Wrangler Technical Forum 27 05-15-2012 09:15 PM
15 Gallon-20 gallon tank mod help needed! Dhofstet YJ Wrangler Technical Forum 9 12-18-2010 09:56 PM
factory 15 gallon vs. 20 gallon fuel tank?? trickle26 YJ Wrangler Technical Forum 19 06-13-2010 05:19 PM
how many gallon tank in a YJ? Bot YJ Wrangler Technical Forum 18 04-11-2006 01:01 PM
hrmm 15gal tank to a 20 gallon tank?? evilpsych YJ Wrangler Technical Forum 4 10-29-2001 06:15 PM
