16.5 rims and tires? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 16.5 rims and tires?
ECGS Black Friday Sale!!6th Annual, Beat Your Wife to the Credit Card Sale!50 in light bar /A pillar mount less than 500 at JeepHut.c
Unread 10-16-2014, 05:24 PM   #1
valingt
Where can I find them?
91 yj LiL Red " http://www.jeepforum.com/forum/f286/lil-red-2797042/ "
valingt is offline   Reply With Quote Quick reply to this message
Unread 10-16-2014, 05:34 PM   #2
Norcal_chris
Norcal_chris's Avatar
All over.
You dont want em. They suck.
2.5/doubler,D60/14bff,108WB,H1s,39.5IROKS 3link front w/ 14in Kings/4 link rear w/ Tj coils
Norcal_chris is offline   Reply With Quote Quick reply to this message
Unread 10-16-2014, 06:08 PM   #3
valingt
Y not and I can't find the right bolt pat
Unread 10-16-2014, 06:09 PM   #4
valingt
Better yet what do I want to go with and stay cheap
Unread 10-16-2014, 06:18 PM   #5
langwilliams
I thought some gm trucks had em. 15's are cheaper, 16's seem to have more selection (if you want to look at something like 285x75x16)
langwilliams is offline   Reply With Quote Quick reply to this message
Unread 10-16-2014, 06:36 PM   #6
Joe Dillard
Electric Chair Operator
http://lmgtfy.com/?q=where+to+find+16.5%22+wheels%3F
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread 10-16-2014, 07:03 PM   #7
Norcal_chris
Stock 16.5 wheels are %99 8 lug pattern.
Plain 16.5 wheels suck as they do not have a saftey bead( some stock 6in wide wheels do however.
This means the tire falls off the wheel at low pressures.
16.5 tires are not plentiful as few tire companies make them.
Only a few mil surplus tires work well.
Putting a 37in mil take off on a dana 30 is a bad idea.
Unread 10-16-2014, 08:52 PM   #8
TSEJEEPERS
http://www.trailworthyfab.com/Hummer...Questions.html
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 10-16-2014, 09:00 PM   #9
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
At least leave me something to respond about damn !
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 12:09 AM   #10
billiebob
Mounting 16.5s is like converting to steam. Nobody uses them anymore.
billiebob is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 02:16 PM   #11
Bigverv
That's some funny ***** right there!
Bigverv is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 02:46 PM   #12
GrantYJ
The only reason to consider going to a 16.5 is if you really, really want double bead locks and "streetability". Hummer double bead locks are awesome after you put a small fortune in them (recenter for proper backspace/bolt pattern, rock rings, and a bead retainer to replace the run flat), but then you have some serious cash tied up in a set of wheels that has a dwindling tire selection.
If that's what you're after, fine, but if you're wanting to run the 36" or 37" military surplus tires, the previous poster was right. You're asking for problems bolting them to a D30.
I have a set of them sitting in the back of my shop. I may end up using them, I may not, but my long term build plan involves tires no bigger than 37" and 8 lug axles. In that range, they may make sense, but I don't like the idea of putting the time and effort to make the wheels right when I might not be able to get off road tires in the future.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline   Reply With Quote Quick reply to this message
Unread 10-18-2014, 10:14 AM   #13
warthog312
The Craigslist Crawler
warthog312's Avatar
Here you go man, this company makes any style, lug pattern, center design, color, along with bead locks and rock rings..... http://www.trailworthyfab.com/12-Bol...al-w-TIRE.html
If you're doing this just for cheap military retired rubbers then stop right now. I know they are on craigslist for a dime a dozen but they are heavy as sin, don't flex when aired down, and eventually they will stop being avaliable which leaves you with a small fortune worth of wheels and no tires; not to mention they will grenade your axles in a heartbeat if you're anything shy of full size with reinforcments.
Click for build thread: HONEYBADGER - 302//435//20//8.8
>>>the single greatest investment you can make for your jeep is to buy a good welder, and learn how to use it<<<
warthog312 is offline   Reply With Quote Quick reply to this message
Unread 10-18-2014, 12:45 PM   #14
Norcal_chris
The mil mtrs work awesome. The baja t/a are nice as well. The MT sucks. But all of them have plenty of sidewall flex.
