15x8 or 15x10 rims for 33's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 15x8 or 15x10 rims for 33's
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 10-12-2001, 01:28 AM   #1
ballasbakker
I want to put 33's on my YJ, and I'm not sure if I should use 15x8 or 15x10 rims. Which ones should I use, and what are the advantages of using one instead of the other?
Thanks!
ballasbakker is offline   Reply With Quote Quick reply to this message
Unread 10-12-2001, 01:32 PM   #2
Tyler
That all depends on what the width of the tires are, what you intend to do with them and what kind of tires.
If you going with 12.50" or less go with 15x8". You have more protection from beads popping when aired down. If you are going with anything wider than 12.5" I would go with 15x10".
If you plan on getting wider tires down the road, go with the 10" wide rims.
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1764091&a=13613281&f=0" TARGET=_blank>
Just an average YJ with 36s</A>
Tyler is offline   Reply With Quote Quick reply to this message
