15x8 or 15x10 rims for 33's - JeepForum.com
post #1 of 2 Old 10-12-2001, 12:28 AM Thread Starter
ballasbakker
I want to put 33's on my YJ, and I'm not sure if I should use 15x8 or 15x10 rims. Which ones should I use, and what are the advantages of using one instead of the other?
Thanks!
ballasbakker is offline
post #2 of 2 Old 10-12-2001, 12:32 PM
Tyler
That all depends on what the width of the tires are, what you intend to do with them and what kind of tires.
If you going with 12.50" or less go with 15x8". You have more protection from beads popping when aired down. If you are going with anything wider than 12.5" I would go with 15x10".
If you plan on getting wider tires down the road, go with the 10" wide rims.
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1764091&a=13613281&f=0" TARGET=_blank>
Just an average YJ with 36s</A>
Tyler is offline
Rims: 15x8 vs 15x10 TimBrown TJ Wrangler Technical Forum 8 07-31-2009 05:03 AM
Any pics of 15x8 vs. 15x10 rims with 33x12.5 rollerized YJ Wrangler Technical Forum 15 04-18-2007 08:29 AM
15X8 or 15X10? mcoughlin YJ Wrangler Technical Forum 11 11-22-2006 08:41 AM
15x8 or 15x10" rims on 4" lift? ryan_289 TJ Wrangler Technical Forum 10 02-25-2005 10:46 PM
15x8 or 15x10 rims JAXTOY 2 TJ Wrangler Technical Forum 5 05-02-2004 07:52 PM
