-   -   14 bolt swap (http://www.jeepforum.com/forum/f12/14-bolt-swap-1532112/)
dlccummins 06-04-2013 12:19 AM
14 bolt swap
anyone done a 14 bolt swap into a yj that can get me measurements of where the perches sit. either from the pumpkin or form the rear of the breaks!!
Joe Dillard 06-04-2013 12:43 AM
I'll move this to the YJ section for you.
Joe Dillard 06-04-2013 12:55 AM
I'm doing a 14B swap right now.
I recently picked up this little jewel. :)
http://www.fototime.com/890F2B58DEB847E/standard.jpg
Since not all 14B's are created equally, what you'll want to do is to measure the center width of how wide you are setting the spring hangers at the frame (if stock width, so be it). Then take that width and replicate it so that your spring perches sit correctly on the tubes equal widths from the backing plates.
In other words....lets say your center measurement for the width of the spring/shackle hangers is 42". If the width between the 14B is 52" (backing plate to backing plate) then you would set/center them 5" from each side while taking into account perch width etc.
Make sense?
jason m 06-04-2013 07:11 PM
That cover still makes me laugh, I say run it for the bling factor but those CA rocks will chew it and crap it out.
Jason.
Joe Dillard 06-04-2013 11:25 PM
Jason.
:teehee: I did a search for the cost of that bling aluminum cover....seems they typically sell for ~$150 which is over 1/2 what the 14B cost me.
The time now is 04:07 PM.
