1310 vs. 1330 vs. 1350 - JeepForum.com
post #1 of 14 Old 10-25-2012, 08:41 PM Thread Starter
rambo3489
Any opinions on any one over the others? I am going to be building my drivetrain from the t-case back and want to try and get it all right. U-Joints are no exception
Thanks
Tyler
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #2 of 14 Old 10-25-2012, 08:44 PM
Pawjob
When i built mine i used the 1310. The reason I did cause I wanted this to be the weak point. Easier to change a U join then axle shaft or R&P.
Pawjob is offline
post #3 of 14 Old 10-25-2012, 08:57 PM Thread Starter
rambo3489
Thats one of my philosophies. I shouldn't break a shaft. (35 spline ford 9") The R&P will be the weak point I feel if I go with a 1350. Is there truth to that?
<a href="
THE YJ MY WAY</a>
post #4 of 14 Old 10-25-2012, 09:12 PM
dillonjm
2013 WK
I wouldn't worry too much about your 9"s R&P with the 4.2 and 35's.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #5 of 14 Old 10-25-2012, 10:40 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I run all 1310's on my rear drive shaft.
I have a 1310 at the Atlas end of the front drive shaft & a combo 1310/1350 at the D60 end. Reason for the front combo ujoint is the D60 typically runs either a 1330 or 1350 series yoke. My D60 came with a 1330 yoke that had one of the ujoint cap tabs broken on it, so I swapped in a 1350 yoke and went with the 1310/1350 combo ujoint. The 1350 sides of that ujoint are a beast in comparison.
Joe Dillard is offline
post #6 of 14 Old 10-25-2012, 10:45 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I don't have a super built jeep but I not only run 1310 but I have one cheap one from autozone in each driveshaft so it will make it an even weaker point should that day come. Well, except for the warrantied super 88 shaft that I broke. I got a mulligan on that one.
There should be a fuse of some sort in every build aspect of your jeep. Something cheap and easy to replace.
Luck Favours The Prepared
Anticanman is offline
post #7 of 14 Old 10-25-2012, 10:45 PM Thread Starter
rambo3489
So did you end up with the 1310's for a specific reason? Or is that the shafts you had/found and went with it?
<a href="
THE YJ MY WAY</a>
post #8 of 14 Old 10-25-2012, 10:49 PM Thread Starter
rambo3489
OK. I smell what your stepping in. Makes perfect sense to me.
<a href="
THE YJ MY WAY</a>
post #9 of 14 Old 10-25-2012, 11:36 PM
Joe Dillard
I went with all 1310's in the rear shaft because they work well & like Nick said - I wanted a built-in fuse.
post #10 of 14 Old 10-26-2012, 01:27 AM
beemerkid
I like the "fuse" idea and I had an instance that somewhat proved that theory. I broke the u-joint on the rear axle yoke of my d35. It also screwed up my axle but I don't think that should be a problem with a stronger one like an 8.8 or d44. I lost the rear half of my custom shaft in the process though...
beemerkid is offline
post #11 of 14 Old 10-26-2012, 05:41 AM
jsawduste
2006 YJ Wrangler
With a Ford 9 inch pinion height so low you would likely be binding with anything other then a 1310 at full droop. Binding is what kills u joints.
Do a search on u joint angularity and you will soon see what the maximum operating angles of the common u joint sizes are. Not to mention what their maximum operating torque load is. Follow those facts rather then the JF opinion poll.
Another option is a 1410 as it has the angularity numbers but nobody makes a 1410 yoke for the 9 inch.
In this case you have little choice.
jsawduste is offline
post #12 of 14 Old 10-26-2012, 06:29 AM
mrmark
in mine I have 1330 at the 8.8 flange yoke and 1310 in the double cardone.
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #13 of 14 Old 10-26-2012, 06:49 AM
TSEJEEPERS
I run 1310.
As long as your driveshaft angle is right you will have no worries.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #14 of 14 Old 10-26-2012, 07:56 PM
kirksjeep
x2. I went with the 1330 at the 8.8 flange yoke so I could use the stock Ford flange which is easy to get at any dealer or junkyard in the event I break it. The stock Ford flange is a lot beefier then the adaptor plates for a 1310.
1992 YJ Sahara- 4.5" RE XD, 1" BL, 1" MML, 35" BFG MT, 8.8 w/Aussie, D30 w/Ten Factory shafts/ Aussie, 4:10 gears, Soild Diff Covers, SYE, CV Drive shaft, OBA, Flowmaster Super 44,, Custom head pipe, Super Chip, Boared out TB, Rock It Intake , Goferit Tie Rod Flip, 99+ intake manifold/Steering pump, custom front/rear bumpers,Hand Throttle, Hurst Shifter, Smitty Built sliders , 6" TJ flairs, Kilby belly up skid, Quadratech 9K winch, ZJ PS cooler. 01 XJ Sport-2" lift, 31x10.50 MT/ 02 Liberty 2" Lift
kirksjeep is offline
