Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Moto Alliance Viper Elite 8,000lb Winch Giveaway!
Go Back   JeepForum.com > Models > Wrangler Forum Group > YJ Technical Forum
Jeep Registry Register FAQ Mark Forums Read Search Members
Old 09-09-2008, 09:52 AM   #1
Jim93YJ
Jim93YJ's Avatar
12 Degrees on Pinion with CV to much??
Does anyone else run near 12 degrees on their rear pinion with a C.V. shaft and have any issues...i.e. pinion bearing lube starvation??
My transfer case output was 5 degrees downward with a 9 degree upward pinion rotation which resulted in a 20" long driveshaft length at ride height and a 16 degree driveshaft angle. The difference is 7 degrees! Waaay to much. I know changing your pinion angle directly effects your driveshaft angle also so putting a 6 degree wedge in there would actually put me with too high a pinion and too low a driveshaft angle.
I figured this by putting my dimensions in a CAD program then constraining everyting so only the pinion could rotate and the driveshat getting longer or smaller. It turns out that 12 degrees of rotaion put the driveshaft at around14 degrees which is 2 under pointing directly at it which is what is recommended for leaf spring setups? (1-3 degrees??).
Any comments or answers to question above would be appreciated
93YJ 2.5L,AX5,Atlas 4.3:1, 4.56 Gears, Dana 30 w/ Posi-lok,Dana 44 Rear w/ Ox Locker + 99 Explorer Disk Brakes,Tom Woods D. Shafts,1" Body, 2.5" ED RE Lift, 31" Pro Comp M/T's with MT Classic II Wheels, Herculined Inside, Flexalite Fan,4.0L Throttle Body, 20 Gal Tank Conversion,Tuffy Center Console,Warn Front Bumper, Rockhard 4X4 Rear Bumper w/ Tire Carrier,Bestop Extended Flares,AMSoil/Redline In Everything and the List Goes On....
AND...
88YJ 4.2L: Interior and mechanical overhaul including engine replacement, nutter bypass, Weber 34 Carb, and work on a whole bunch of other things to get it back to fine running condition without the emissions control...evap cannister kept functional as well as PCV system, and manifold heater.
Jim93YJ is offline   Reply With Quote
Old 09-09-2008, 11:30 AM   #2
Jim93YJ
Jim93YJ's Avatar
Anybody with an opinion???
AND...
pinion angles: is 8 degrees difference too much mikaus TJ Technical Forum 21 09-22-2009 06:26 PM
Pinion off by 5 degrees elkfan2 TJ Technical Forum 6 04-20-2009 07:11 PM
minus 10 degrees sandman'sjeep YJ Technical Forum 13 02-06-2007 08:29 PM
RE4.5SF or Nth degrees 4.5 'B'wigstrailrig TJ Technical Forum 3 09-18-2006 06:57 AM
215-225 degrees too hot? 97 TJ'd up TJ Technical Forum 1 07-18-2006 07:42 PM
The time now is 12:57 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
