10w30 in AX-15 anyone? - JeepForum.com
post #1 of 16 Old 01-21-2010, 02:38 PM Thread Starter
lollygagger8
Who's running 10w30 in their AX-15?? The newest part number from Chrysler translates into that oil for the AX-15......anyone using it?
Does it shift better/worse?
96 Cherokee Sport w/ 4.0L, AW4, NP231, 4" Rough Country Lift, 31" BFG AT's
lollygagger8 is offline
post #2 of 16 Old 01-21-2010, 02:48 PM
bigh20rnr
bigh20rnr's Avatar
1987 YJ Wrangler
I use it and have no complaints. I switched from Mobil 1 synthetic 75-90w and it improved the shifting dramatically in my reman trans. Works fine down to well below zero regardless of whether I plug in the block heater or not. Mean Max recommended it to me and I have not looked back.
Rick
87 YJ 4.2L, Weber 32/36, rear bumper tire carrier, nutter bypass, RE 4 inch lift, SYE, AX 15, lined the body tub
"Baby when you said you wanted a project jeep I expected you to spend a lot of money on it" <---Worlds best wife!!!
bigh20rnr is offline
post #3 of 16 Old 01-21-2010, 02:50 PM
jsahara24
http://www.jeepforum.com/forum/f12/1...51/index2.html
I personally run Redline in my jeep but there are a lot of people who run 10W30 and are happy with it. Seems to be a fairly even argument..
99' Jeep Cherokee Sport
07' Toyota Matrix
jsahara24 is offline
post #4 of 16 Old 01-21-2010, 02:51 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
10w30 in mine. Shifts great, even in the coldest of weather.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 16 Old 01-21-2010, 02:55 PM
machinehead131
Redline mt-90 in mine
I use it in my car as well so I just buy cases of it. Works great for me but im sure 10w30 would work fine.
I am sticking to specific MT oil though. Doesn't have short intervals for changing either so cost isnt much of an issue.
Looking for TJ Rear Flares, if anyone has any please PM ME.
Thank you.
machinehead131 is offline
post #6 of 16 Old 01-21-2010, 03:08 PM Thread Starter
lollygagger8
I'm running Redline MT-90 as well, and it's shifting, but could shift much better. I'm sure my sychros are slowing dying, but I want to try the motor oil to see if that helps.
Thanks guys!
post #7 of 16 Old 01-21-2010, 03:35 PM
mojeep
I ran 10w30 for a while shifted ok, changed it out to penzoil syncromax way smoother up and down, could tell a difference almost immedeately.
mojeep is offline
post #8 of 16 Old 01-21-2010, 03:39 PM
brunolinski
I have had the 10w-30, royal purple, and now the redline. Redline is the best performing......but you're still SUPPOSED to put 10w-30 in it.
brunolinski is offline
post #9 of 16 Old 01-21-2010, 03:40 PM
4.7stroker
I am using ATF going for 2+ years no problems and shifts great.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #10 of 16 Old 01-21-2010, 03:47 PM
ufatbastehd
I've been using Penzoil Syncromesh for a year and so far she has been shifting like butter.
Used to use Redline but she feels better with the Syncromesh
ufatbastehd is offline
post #11 of 16 Old 01-21-2010, 03:48 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
10w-30 all the way.
http://www.jeepforum.com/forum/f12/b...change-865520/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #12 of 16 Old 01-21-2010, 03:54 PM
mojeep
You can get by with many different lubes but redline isn't widely avail. and I'm telling you from recent back to back test penzoil shifts smoother than mobil1 full syn 10w30. no comparison
mojeep is offline
post #13 of 16 Old 01-21-2010, 04:34 PM
postaldave
Syncromesh
postaldave is offline
post #14 of 16 Old 01-21-2010, 05:27 PM
Leans93
She's my density...
Leans93's Avatar
10W30 here and no issues
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #15 of 16 Old 01-21-2010, 06:14 PM
Louie4
Been running it since last Summer. Shifts great.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
Swapping 10W30 for 10W40 Bubba3200 TJ Wrangler Technical Forum 7 12-10-2009 12:16 AM
switch from 10w30 to 10w40 oil jesse977 TJ Wrangler Technical Forum 1 01-08-2009 04:46 AM
Mobil 1 10W30 Full Syn SibTJ2005 TJ Wrangler Technical Forum 11 09-02-2007 10:34 AM
5w30 vs.10w30 oil jkoffroadin TJ Wrangler Technical Forum 2 03-19-2006 01:54 AM
Valvoline Duramax 10W30 Spiderman TJ Wrangler Technical Forum 4 10-24-2004 12:23 AM
