10in to 9 in brakes - Page 3 - JeepForum.com
post #31 of 33 Old 01-08-2012, 12:53 AM Thread Starter
y87j
1987 YJ Wrangler
Alrighty guys I will try her again tomorrow ... but it should deff fit? How do I change the front brakes from 87 to94 rotor and pads... thank you
y87j is offline
post #32 of 33 Old 01-08-2012, 09:31 AM
dodger889
That will not work. Not unless you want to change out the backing plate for the calipers, calipers, pads and rotor or change out the outer C's with everything else attached.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #33 of 33 Old 01-20-2012, 04:17 PM Thread Starter
y87j
1987 YJ Wrangler
Originally Posted by 94chb View Post
^ i believe he is talking about the studs on the axle Tube and not the studs on the wheels.
ive always seen 4 studs, never a 5 .... yet.
my 98 grand cherokee dana 35 even ha
Yes their is 4 studs but their is also a hole above on the backing drum making it 5 hole and four studs
y87j is offline
Knocking: front brakes, rear brakes, drive shaft(?) Ujoints Or Drums? Help? VanBCguy TJ Wrangler Technical Forum 14 01-31-2013 08:34 AM
Brake upgrade for those running D44/Chevy brakes(waggy brakes included) RockRodHooligan TJ Wrangler Technical Forum 29 11-09-2012 06:23 AM
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Wrangler Technical Forum 18 12-30-2009 08:55 PM
95 Front brakes are dragging rear brakes lock up instantly 72RatCamaro YJ Wrangler Technical Forum 2 03-18-2009 07:25 AM
Brakes brakes brakes....Whos got good brakes? Tacoma750 TJ Wrangler Technical Forum 20 12-17-2006 10:15 AM
