102 Inch Whip Antenna Technical Issues With Use In Groups - JeepForum.com
post #1 of 15 Old 11-02-2008, 12:09 AM Thread Starter
Delta347
This is a basic question about the technical reasons, if any, to why clubs don't allow 102inch Whip Antennas. I was interested in getting one for the look to match my rig better but my roommate said they weren't allowed by a lot of groups but he didn't remember why.
I was wondering if there was any technical reason such as power output that are the reason. Or if you know if there isn't a problem with the specific style I am getting. A 102 Inch Stainless Steel Whip Antenna.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #2 of 15 Old 11-02-2008, 12:54 AM
plumber1
because they whip. 102" if not tied down swings around a lot and people were getting hit with them, while helping to spot for the driver. They were also getting hit while trying to rock a stuck jeep.
plumber1 is offline
post #3 of 15 Old 11-02-2008, 01:09 AM
rrisher
1987 YJ Wrangler
Makes sense to me. You're running a line of sight communication without a repeater, so the higher the antenna the better transmitting and receiving range.
rrisher is offline
post #4 of 15 Old 11-02-2008, 09:26 AM
hunkajunk
As far as technical performance and simplicity you can't beat the 102" whip. BUT, like the previous poster said. You will beat the ever-livin snot out of your trail side companions. I have seen mine cut 1" thick tree branches like they were nothing.
I like mine, but I make sure it is SECURELY tied down on the trail.
95 YJ 2.5 Low Output
hunkajunk is offline
post #5 of 15 Old 11-02-2008, 10:27 AM
ElvisV04290
ElvisV04290's Avatar
I run one, and love the performance, but like the others have said it's dangerous when it flies around, so I always have mine tied down when on the trials.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
post #6 of 15 Old 11-02-2008, 10:34 AM
johnrezz
Just get a fire stick and make sure you install everything properly, use the right length of wire and go buy an SWR meter. You will get great performance, not as good as a 102" but pretty darn close.
You will not be happy the first time you go under some low limbs and that whip comes back an smacks the S*&^ out of you or your passanger.........
dont forget that when using a steel whip it is imperitive that the whip stays in good shape, the signal will be degradated once the whip gets damaged hitting trees and other obsticals, so eventually you will wind up with about the same performance as a firestick.
I spent 10 years as comm tech in the USMC and basically the local CB guy when I was stationed in NC....
It is funny when I was in NC there were tons of people to talk to on the CB, out here in Colorado unless I go wheelin with someone that has a CB I have never (not kidding) Never had a conversation on the CB, and I have tried. I can pick up some skip but never anyone local.....
1989 YJ 258CI 4.2L with 4.0-HO(7120)5 angle head job, Comp-Cam 4x4 xtreme cam, Holley 4412 500CFM Carb, Clifford performance single Plenum intake, CRT HEI distributor, Rough country 4" lift, 33.5 tires, Ultra Polished Aluminium Rims, Warn Powerplant, Galaxy DX-979 w/ a little help-x-250, custom tire swingout rear bumper, quick disconnects, Posi-Loc, new paint.
My build thread:
johnrezz is offline
post #7 of 15 Old 11-02-2008, 12:51 PM
xeroid81
As john says, that whip is a 1/4 wave antenna. You can by a fiberglass 3/4 wave or a shorty like the one he mentioned. Those are loaded with a wire wrapped around the outside to equal standing wave ratio of the whip! You can do a clamp mount to the roll bar with a shorty also to get the height needed for line of site. That way you can take it down when the top is on also.
xeroid81 is offline
post #8 of 15 Old 11-02-2008, 03:06 PM
GrimJeeper91
GrimJeeper91's Avatar
If you want a whip simply put a flag on it and it stops the whipping.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #9 of 15 Old 11-02-2008, 06:01 PM
93jeepREDSOX
i have a whip, with an angry snowman on it and it keeps it from flying all over. I love how clear the conversations are on it.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #10 of 15 Old 11-02-2008, 11:23 PM
RikRotorhead
You guys are talking about 'whips' and 'beatings' and stuff.
This is a FAMILY site for heaven's sake!
Fire Stick is the way to go. Just as clear as the RS-102SS whip.
A good ground connection, dialed in correctly with an SWR bridge, and a good ground plane mounting location. The middle of your hood would be the best spot, but not for looks.
The radio waves hit the ground plane, and umbrella up and out.
So mounting them low or behind the vehicle on the rear bumper are not good locations.
My $ .02 worth.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #11 of 15 Old 11-02-2008, 11:25 PM
Brandon_YJ
1987 YJ Wrangler
K40 FTW!!!!
Sorry,
I've had the same K40 antennea for over a decade now and it still works great!
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #12 of 15 Old 11-03-2008, 05:30 AM
RobsYJeep
do any of you have pictures of mounting locations? I was split between the bumper and getting a prefab mount that gets sandwiched between the taillight and tub....
thanks
Rob
RobsYJeep is offline
post #13 of 15 Old 11-03-2008, 06:38 AM
ElvisV04290
Mine is mounted to the spare tire bump stop.
post #14 of 15 Old 11-03-2008, 04:02 PM
RobsYJeep
hmmm... I hadn't thought of that..
post #15 of 15 Old 11-03-2008, 04:21 PM
jamaicanmecrazy
1994 ZJ
Nothing beats the whip but the Browning's also are hard to beat. Handles a 1000watt heater also.
And nobody will get whipped to death.
jamaicanmecrazy is offline
Antenna Whip yjweeler YJ Wrangler Technical Forum 3 04-18-2009 04:22 PM
Technical issues with "new" Rubicon SECorBust Wrangler General Discussion 14 04-13-2009 10:43 PM
2 inch lift issues!!! joppermann TJ Wrangler Technical Forum 31 07-20-2007 10:51 AM
Tail light and antenna mount issues... need some opinions (pics inside!) thejafe TJ Wrangler Technical Forum 4 10-05-2005 10:59 AM
CB Antenna Issues BeatAChevy289 YJ Wrangler Technical Forum 1 03-30-2004 10:32 PM
