10" drum brake strut bar Help - JeepForum.com
post #1 of 12 Old 10-30-2014, 02:19 PM Thread Starter
HB223
I'm looking for a 10" drum brake strut bar for the "left" side. I found a right side, Im guessing that the left and right side are the same shape? Here's the right side: http://www.ebay.com/itm/Rear-Drum-Br...ht_1219wt_1010
HB223 is offline
post #2 of 12 Old 10-30-2014, 02:39 PM
Old4X
1990 CJ7
That is a common maintenance part. Try your local NAPA
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 12 Old 10-30-2014, 06:17 PM
Drednot
Yeah . That's available at Napa. I think they have a right and left if its not flat.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #4 of 12 Old 10-30-2014, 07:50 PM Thread Starter
HB223
that's aint a common maintenance part anymore. Nobody carries them. I tried all over even the dealer. That still doesn't answer my question tho?
HB223 is offline
post #5 of 12 Old 10-30-2014, 07:54 PM
fishadventure
NAPA had them in stock when I did mine
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is offline
post #6 of 12 Old 10-30-2014, 07:58 PM Thread Starter
HB223
how many years ago?
HB223 is offline
post #7 of 12 Old 10-30-2014, 07:59 PM Thread Starter
HB223
DO you know if the right side is same shape as the left???????
HB223 is offline
post #8 of 12 Old 10-30-2014, 09:26 PM
fishadventure
how many years ago?
Nope. Don't remember. But I want to say there is an offset so they're not interchangeable. But if I remember correctly the kit contained both? Don't fully recall. If it was two bags of parts or one? Can't remember.
When you go to NAPA if they ask you which side though you should tell them the correct side you need.
I rebuilt the rear brakes on a '91 in August 2013 and on my '89 in March of 2014.
post #9 of 12 Old 10-30-2014, 09:39 PM
baritone_mike
I bent my right one into a U shape when it came loose driving down the road at 35mph. That was a loud bang and a very violent jolt. I grabbed the left one out of an XJ and it worked no problem.
The left and right are not the same shape though, they are not flat. I have put 10k miles and 2 years on it and have not had any issue even though it is upside down.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #10 of 12 Old 10-30-2014, 10:24 PM Thread Starter
HB223
I had the brakes rebuilt on mine but in order to get the park brake to work i need that darn left side. I will go by Napa and see what they got. I haven't actually walked in the store, just went online.
HB223 is offline
post #11 of 12 Old 10-31-2014, 08:38 AM
Rebel442
Lee auto parts had them on the shelf about a month ago when i did mine. They come with the master or full hardware set.
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline
post #12 of 12 Old 10-31-2014, 05:22 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
http://www.4wheelparts.com/Brakes-St...=540&t_pt=7979
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
