1 inch bl - JeepForum.com
post #1 of 18 Old 08-25-2013, 10:34 PM Thread Starter
Tyler980
1 inch bl
Can anyone recommend a cheaper 1 inch bl? I've been looking around the web but most seem to be around 150? Also can't find a write up for the install on a yj with only 1 inch
Tyler980 is offline
post #2 of 18 Old 08-25-2013, 11:00 PM
YJ4LIFE
http://www.summitracing.com/parts/pr...gler/year/1989
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #3 of 18 Old 08-26-2013, 12:58 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I really liked the prothane one I had on my 95 YJ but it was $150 I considered it to be priced great considering it was not a spacer it was a 1" taller mount with all the hardware
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #4 of 18 Old 08-26-2013, 07:46 AM
bob6987
I installed the prothane 1" body lift. it was nice because it replaced all the old parts...it $145 but well worth it over the puck versions.
I did need to get a different bolt for the front center bushing. was .5" to long and could not be tightened without pushing up into the grill.
no real need for a write up to do the install. it will take a couple hours if you are by yourself.
replace all the bolts, pb blast a needed, with the longer bolts in the kit. install them enough to hold body in place but allow you to lift body off frame.
then lift body off frame about 1.5" on one side, replace bushings and repeat on other side. leave all bolt loose until al bushins are swapped.
you will need to do a motor lift at the same time or relocating the fan shroud.
1991 YJ, 4.0, 6" lift, 40" tires, full cage, dana44/ford 9, detroit locker, 5.38 gear
2012 JKU
bob6987 is offline
post #5 of 18 Old 08-26-2013, 08:18 AM
Tom95YJ
Tom95YJ's Avatar
I never needed to to a MML with my 95. But I was not running a tc drop either I did add a 1" Mml to mine when I did a flat belly pan
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #6 of 18 Old 08-26-2013, 09:13 AM Thread Starter
Tyler980
So if I do the 1 inch bl without mml. I need to relocate fan shroud lower, do they sell relocation brackets or something? Or do I need to create new holes?
Tyler980 is offline
post #7 of 18 Old 08-26-2013, 01:44 PM
YJ4LIFE
my PA kit came with brackets but I just lowered the fan shrowd
YJ4LIFE is offline
post #8 of 18 Old 08-26-2013, 01:47 PM
Tom95YJ
Tom95YJ's Avatar
Do a eletric fan conversion and you won't need a fan shroud
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #9 of 18 Old 08-26-2013, 04:09 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I just used some self tappers. No biggie.
However I'm lookin at doing a writeup on a $30 body lift that takes a little work to put together.
Luck Favours The Prepared
Anticanman is offline
post #10 of 18 Old 08-26-2013, 05:18 PM Thread Starter
Tyler980
Well send the link my way after you do the writeup canman. And I think I may skip doing the mml and just relocate shroud
Tyler980 is offline
post #11 of 18 Old 08-26-2013, 07:05 PM Thread Starter
Tyler980
Is there a writeup on this? Or a post with a suggestion on which e fan to get?
Tyler980 is offline
post #12 of 18 Old 08-26-2013, 07:13 PM
crackedcornish
plenty of good write-ups on all sorts of stuff in the FAQ's
like this one
http://www.jeepforum.com/forum/f12/e...rk-vii-506679/
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #13 of 18 Old 08-29-2013, 09:28 PM Thread Starter
Tyler980
Are shackle lifts worth doing? I've seen some things people say regarding them as dangerous? Are they easy to install as well?
Tyler980 is offline
post #14 of 18 Old 08-29-2013, 09:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
post #15 of 18 Old 08-30-2013, 06:03 PM Thread Starter
Tyler980
Now if I did a 1.75 inch boomerang shackle lift with 1" body lift would I need to extend or swap out anything else?
Tyler980 is offline
