1"bl now 4wd light stuck on - JeepForum.com
post #1 of 4 Old 10-17-2011, 07:04 PM Thread Starter
mbaseel
Hey guys so I have been googling and searching forums and cant seem to find anything on what I am looking for... so here is the problem...
I installed a 1" body lift and now my 4wd light is stuck on. This is more annoying than anything cause it goes into 2wd and drives fine but the light stays on. Any suggestions on what may have happened and how to fix this?
thanks for the help,
Mike
mbaseel is offline
post #2 of 4 Old 10-17-2011, 07:45 PM
Louie4
"You pass butter"
Louie4's Avatar
My 4WD light was stuck on for about 6 months at one point. I finally got under there and unbolted the CAD cover and cleaned the vacuum shift motor with some brake cleaner. After that it worked fine. That was about 8 years ago.
Another thought is to check all your vacuum lines. You might have pulled something loose when you were doing the body lift.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 4 Old 10-19-2011, 09:00 PM Thread Starter
mbaseel
So I got under an checked the vacuum lines and where the 4 lines plug into the transfer case only one has vacuum and only one of the lines has vacuum at the cad. I was able to switch the one that was working over to the spot of the one that wasn't working on the cad and the 4x4 disengaged and it is now in 2wd. I think this is either pointing to a sensor or cracked line. Any other suggestions?
mbaseel is offline
post #4 of 4 Old 10-19-2011, 10:26 PM
Louie4
"You pass butter"
Louie4's Avatar
It might be the vacuum switch that the 4 line plug went to. When you shift to 4wd it routes vacuum to the other line on the axle to disengage the CAD system in the front axle. I wouldn't rule out a cracked vacuum line though.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
4wd , 4x4 , bl , body lift
Daytime Running Lights Make my "Bright" light dash light indicator go out??? reisom TJ Wrangler Technical Forum 3 05-05-2011 01:07 PM
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 09:29 AM
4wd light stuck on watkins 92 yj YJ Wrangler Technical Forum 6 10-14-2006 12:19 PM
4WD Light Stuck on Tom Rex YJ Wrangler Technical Forum 4 11-13-2005 11:09 PM
