Quantcast 1/4 Tank = Stall Out On Sharp Left Turns - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1/4 Tank = Stall Out On Sharp Left Turns
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 01-26-2006, 11:54 PM   #1
codyman
Whenever my gas gauge reads at or below quarter of a tank remaining, anytime I take a sharp left turn, it either sputters or even sometimes completely stalls. I'm assuming maybe fuel pump?
Jeep #1: 1989 Wrangler 2.5 5 Speed
STATUS: STOCK w/ 31x10.5's & Aftermarket Rims (Modifications begin soon)
Jeep #2: 1999 Grand Cherokee 4.0
STATUS: STOCK (Daily Driver - No Mods Planned)
codyman is offline   Reply With Quote
Old 01-27-2006, 12:20 AM   #2
KyleS
Guages in Jeeps don't always read perfectly. Mine is OUT of gas right as it hits the last part of the guage where it turns to red, and I owned one that would be out at 1\4 tank I ran 1\2 a can of Sea foam through my tank and it worked perfectly again I never really understood how that fixed it but I was just happy it worked. I also had a problem with my last wrangler stalling when it got low on gas until I replaced my fuel filter, so if I were you I'd start with a new fuel filter. Also watch your milage and see if by the time you hit a quarter tank if it should be empty. My guess would be its the filter, then the fuel guage, and I really doubt its your pump but if you doubt it just hook a pressure guage up to it and find out.
KyleS is offline   Reply With Quote
Old 01-27-2006, 12:24 AM   #3
codyman
Few questions:
1. For that sea foam stuff, is that a gas additive or some sorta spray into the tb?
2. I'm planning on buying a "tune up kit" for my 2.5 .. goes for like 40 bucks and has wires, plugs, fuel filter, etc so I"ll start with that and see if that helps any (can't hurt).
3. What is the size of an 89 2.5 gas tank anyways?
Old 01-27-2006, 05:52 AM   #4
fratis
fratis's Avatar
inside your tank your pump sits inside a little plastic trough. this helps to minimize gas running away from your pump at low levels and under turning. had trouble with mine and this plastic part was messed up. your pump might also not be sitting all the way on the bottom of the tank. couple of things to look for.
fratis is offline   Reply With Quote
Old 01-27-2006, 10:31 AM   #5
Brown Dog
Vendor
Brown Dog's Avatar
I just worked on an 89 with the same problem. As fratis said, it was the plastic baffle in the tank that was distorted and useless. In the case of this Jeep, it was in a left turn, just as you say.
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Join our FaceBook group
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% MADE IN AMERICA
OFFROAD-REVIEW of Browndog Superkit
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" BFG Mud Terrains
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Old 01-27-2006, 11:25 AM   #6
superjoe
i ahve that problem but it has to be under 18th of a tank, but with my spool in the rear and now sway bar or trac bars i have MAJOR body roll when making tight turns (yes even very slow) if i put any speed to the turn it kills the engine.
Joe Clark † 210-639-0276
/l ,[____], 82 CJ 8 Scrambler Currently all stock but that will change.
l---L--0lllllll0- Christian 4x4.com
()_) ()_)----)_)
superjoe is offline   Reply With Quote
Old 01-27-2006, 11:36 AM   #7
wolf3902
The tank is a 20gal. but has an extended vent tube so that it only holds around 15 gals. Depending on how the Jeep is sitting (tilted or flat/level) you'll get more or less that 15 with the auto shut off on the pumps.
Mine actually starts sputtering on turns and then is empty at around 1/4-1/8 on the gauge. I bet yours is the same and you're running low.
'93 YJ 2.5 Jasper; 5 speed
All stock, waiting to be reborn.
6/19/05 ...2" BDS suspension lift...the rebirth has begun!!!
ONE NATION, UNDER G O D
Support It, or Leave It!
wolf3902 is offline   Reply With Quote
Old 01-27-2006, 02:25 PM   #8
fratis
fratis's Avatar
went to the doctor and said, "doctor it hurts when i do this" he says, "well... dont do that." not to be an *** but it looks like the simplest and cheapest fix is to simply keep more fuel in the tank.
Old 01-27-2006, 10:43 PM   #9
codyman
When I fill up, I fill up completely. When the 1/4th sputter problem begins, I refuel. In terms of this plastic thing, is there a replacement part or would you need a new fuel tank? Its not that big of deal, basically I fill up with a quarter tank left and considering this is my project car / 4th car in the driveway, currently I go through 3/4 of gas maybe once every 3-4 weeks.... hopefully once I fix her up I'll be using her more
Old 01-28-2006, 11:17 PM   #10
fratis
fratis's Avatar
good question. ive never seen the item advertised by itself. since its not your sole mode of transpo id drop the tank and actually see. it might simply have broken away and be sitting in the tank but otherwise be fine.
Old 01-28-2006, 11:38 PM   #11
codyman
Well, I'll have to wait a little while to drop the tank... just did a full fill up today... How long does it normally take to drop the tank anyways? I have a chilton's manual somewhere in my mess of books that should tell me how to do it...
Old 01-29-2006, 02:39 AM   #12
fratis
fratis's Avatar
the hardest part are the stupid fill lines. you have to disconnect them and push them out of the way before you can lower the tank. other than that is pretty quick.
Old 01-30-2006, 12:16 AM   #13
j-man
EXACT same thing happened to me. sharp left turns. you need to reposition your fuel pump
1988 Red Wrangler
2.5L 4 banger
soft top, half doors
pioneer cd deck, sony xplode speakers
cragar rims/30" continental
soon to come:
2.5 spring lift
1" body
31" tires (i like fender clearance :) )
[COLOR=Red]Red Jeep Club #297[/COLOR]
j-man is offline   Reply With Quote
Glock Forum
