1.25 inch boom shackles - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1.25 inch boom shackles
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 12-24-2014, 12:17 PM   #1
cwein23
I have 2.5 inch straight shackles in the front right now, and stock shackles in the rear. The 2.5" shackles look horrible and ride horrible, so along with the bastard pack Ill be doing soon, I wanted to shorten the shackles.
Does anyone have any pictures of 1.25" boom shackles? Also, how would it ride? I didnt want to go over 1" booms, but theres some 1.25" ones for all four springs for a good deal...
Thanks
cwein23 is offline   Reply With Quote Quick reply to this message
Unread 12-24-2014, 12:38 PM   #2
Anticanman
Follow me
Anticanman's Avatar
You're still going to have a terrible ride with the shackles over an inch. I wouldn't suggest them for steering purposes over 3/4" lift length. You will probably be better off not having some beaver teeth on the front of your jeep and sourcing a better spring lift for quality purposes.
And no, I don't have any pics of what my jeep looked like with huge shackles on the front. However I'm still running 1" booms in the rear.
There is only one pic I could find offhand
Luck Favours The Prepared
[SIGPIC][/SIGPIC]
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 12-24-2014, 12:52 PM   #3
cwein23
thanks for the quick response!
unfortunately a complete suspension lift isnt possible. Im only 16 and having dumped 3k+ just to fix the jeep up, my mom would kill me if I spend 500 on springs.
Im getting the bastard pack springs for free, and the shocks for a steal, so Im trying to shorten the shackles as much as I can while being able to keep my 33s.
Would going to a 1" shackle make a difference? I know you suggested 3/4 inch, but that pushing it in regards to my clearance. Thanks again
Those are sweet wheels by the way, did you have those done custom?
Unread 12-24-2014, 01:07 PM   #4
Anticanman
Follow me
Anticanman's Avatar
So you are trying to keep your 33's under the jeep without spending a lot of money. I think we can do this step by step with minimal cash flow.
First of all, buy a sawzall or whatever kind of reciprocating saw you want at harbor freight. Then go to a reputable hardware store and get some really good blades for steel.
Next, go ahead and cut and redrill your shackles at 5" hole to hole and cut off the excess. Ain't nobody got time for shackles that long. The beaver belongs in the passenger seat, not the face of the jeep.
Check craigslist for some TJ flares. You can also cut your own to gain another inch of clearance but the TJ style gives more overall plus you can take the aforementioned reciprocator and trim away sheet metal. Here's the difference between trimmed Yj flares and where the TJ flare lines up with the Yj sheet metal
Next go spend about $100 on a 1" quality body lift. This should get your 33's about the same distance away from your fenders as they would be with the crap shackles.
[SIGPIC][/SIGPIC]
Unread 12-24-2014, 01:08 PM   #5
Anticanman
Follow me
Anticanman's Avatar
And yes, they're custom wheels.
[SIGPIC][/SIGPIC]
Unread 12-24-2014, 01:20 PM   #6
cwein23
I hate to make this difficult, but I already have a BL on, and my flares are trimmed already. Ill look on craigslist for some TJ flares, but I was looking to just take the rear ones off entirely and cut the sheet metal up.
As for cutting the sheet metal in the wheel well, whats "okay to cut" and what should I avoid cutting? Before I just start hacking away at it
The wheels look great, props to the spades design as well, I like it a lot
Unread 12-24-2014, 01:23 PM   #7
Anticanman
Follow me
Anticanman's Avatar
Just make sure you move the wires before you hack into it. And if you're going to use an angle grinder with a 4.5" cutoff wheel, make sure you don't smell any gas before you cut the driver's side. Other than that, you can push the plastic pieces back and cut a little and still use them or rip them out entirely but hit the bare inner center with some rattlecan undercoating. It really deadens the sounds.
You have a pic of the jeep as is?
[SIGPIC][/SIGPIC]
Unread 12-24-2014, 01:37 PM   #8
JonCorwin
Cwein when you say 1.25" shackles, do you mean 1.25" of lift or 1.25" over stock length?
JonCorwin is offline   Reply With Quote Quick reply to this message
Unread 12-24-2014, 01:47 PM   #9
cwein23
http://s79.photobucket.com/user/supe...tml?sort=3&o=0
Heres some pictures, and theres very little plastic in the wheel well (front wheel well at least), was some taken out by the PO or am I just missing it?
EDIT: cant figure out how to post the pictures link-less...
JonCorwin, I mean 1.25" lift. The longest I wanted was max 1" lift, but someone found me a deal on 1.25" booms that I cant find on the 1" lift ones.
Unread 12-24-2014, 02:37 PM   #10
Anticanman
Follow me
Anticanman's Avatar
[SIGPIC][/SIGPIC]
Unread 12-24-2014, 02:39 PM   #11
Anticanman
Follow me
Anticanman's Avatar
Honestly, I would sell the tires for some decent 31's and call it good. Roll with some smaller rubber for a while.
[SIGPIC][/SIGPIC]
Unread 12-24-2014, 03:41 PM   #12
plym49
This.
And lose those retarhrded front shackles.
plym49 is offline   Reply With Quote Quick reply to this message
Unread 12-24-2014, 04:06 PM   #13
cwein23
Okay. Ill shorten the shackles to 3/4 " lift or max 1" once I get the bastard pack.
If theres not enough clearance, Ill go for 31s
