1/2" lift shackles effect on steering? - JeepForum.com
post #1 of 17 Old 07-06-2013, 01:28 AM Thread Starter
cyoos
I'm getting ready to install a 2.5 OME lift on my YJ. I have two sets of heavy duty shackles; one is standard 4", the other is 5" boomerangs.
I'm wondering how much the 1/2" lift booms will effect my steering. I read numerous threads on different forums, but haven't found anything that would pinpoint this answer. I realize that the small shackle lift will change the caster angle, but I'm hoping to hear from voices of experience with similar suspension setups.
Does the slight lift throw the caster off enough to install caster shims?
Return to center?
Bump steer and wander?
I'll be running 31's or 32's (with body lift) if that has any bearing on it.
All input wil be appreciated.
cyoos is offline
post #2 of 17 Old 07-06-2013, 05:33 AM
rogerv
I ended up having to put a small shim in mine when I went to 1/2" booms. My 89 also has a 4" lift, running 31's. I also threw away the trac and sway bar. The return to center was effected slightly, but driving down the road without the shims was greatly improved after I put shims in. Play with the torque on your shackle bolts, took me a few times to find its sweet spot, but don't over tighten them.
rogerv is offline
post #3 of 17 Old 07-06-2013, 06:01 AM
dillonjm
2013 WK
It will be slightly lighter, but if you don't have any loose components to begin with it'll be just fine.
I tried out a few different shackle configs in my YJ and found I liked the 1/2" booms the best.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #4 of 17 Old 07-06-2013, 07:15 AM Thread Starter
cyoos
Thank you.
I've also been playing with the thought of simply trying both sets to see where it got me. That in itself still may not be a bad idea, but the standard set was shipped to me by accident after I had already received the 5". So it's put me in the unique position of trying to decide which set to send back, or sending payment for the standards and trying out both sets.
cyoos is offline
post #5 of 17 Old 07-06-2013, 07:51 AM
UZI4U
Kind of a side question...where do you get 1/2" lift boomerangs for the front? All of the places I see advertise them as being for the rear only.
MCLMM
UZI4U is offline
post #6 of 17 Old 07-06-2013, 07:57 AM
rogerv
UZI4U- I got mine from Ground Pounder Fab. The owner is a forum member over in the CJ section. Excellent product for the money.
rogerv is offline
post #7 of 17 Old 07-06-2013, 08:02 AM
Siva283
Also there is no difference between front and rear shackles.
And another vote for ground pounder.
Sent from my SPH-L300 using JeepForum
Ask me how I know...
Siva283 is offline
post #8 of 17 Old 07-06-2013, 08:10 AM Thread Starter
cyoos
Also, the torque on the shackle bolts is the one point that was stressed in all of the threads I read. Most were using 40-45 ft-lbs on them, and around 60 on the frame bolts as I recall.
cyoos is offline
post #9 of 17 Old 07-06-2013, 08:15 AM Thread Starter
cyoos
I got mine from Jim Crabtree, Crabtree Tool & Die, in Perry, MO.
From what I've read the front shackles are installed short leg up, whereas the rear shackles are mounted long leg up. The "V" on both ends point inward to the center of the Jeep.
cyoos is offline
post #10 of 17 Old 07-06-2013, 12:52 PM
RockWoRM
RockWoRM's Avatar
Keep in mind that quote is for locknuts. Standard nuts/washers can re-loosen at the lower torque settings.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #11 of 17 Old 07-06-2013, 02:59 PM Thread Starter
cyoos
WRM
Correct! Thanks for adding that.
cyoos is offline
post #12 of 17 Old 07-06-2013, 11:33 PM
imstillatwork
I use 3/4" front and rear. stock pitman. no shims. no bumpsteer at all, steering return to center on it's own.
imstillatwork is offline
post #13 of 17 Old 07-13-2013, 11:59 PM Thread Starter
cyoos
It sounds like it's holding true that no two Jeeps react alike. In that case...EXPERIMENT!
cyoos is offline
post #14 of 17 Old 07-14-2013, 12:03 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yes its true that every jeep is different but its a universal truth that longer shackles exacerbate existing problems more than create their own. Go up to an inch lift if everything else is squared away.
Luck Favours The Prepared
Anticanman is offline
post #15 of 17 Old 07-14-2013, 12:42 AM
Sparrows
I run 1/2" booms with my ome springs. Everything seems to work great. I'm going to throw out BESRK for shackles. Pm him here on the boards. You won't find a better price, he is awesome to deal with, his product is great, and shipping is quick.
Cheers
June '13 YJOTM
Sparrows is offline
caster , lift shackles , steering alignment
