.060 overbore ok in 4.2????? - JeepForum.com
post #1 of 14 Old 02-23-2009, 03:33 PM Thread Starter
bigrobby
1990 yj 4.2 190k
we're tearing down the 4.2 and have plenty of power adding plans....but my only question is how much can i safely bore it out?
well...is .060 ok???
i'm pretty sure there's plenty of meat on the cylinder walls for .060 but my machine shop guy wants me to check with some people and make sure that much of an overbore didnt cause overheating problems.
anyone know????
thanks
92 yj, 4.0 H.O. with crane cam 753901 and lifters/ ford 8.8 track lock and disc rear/3.73/ 231 HD chain & sprocket/ Teralow HD SYE/Tom Woods DS/ bout 4 inches mixed susp lift/ 33" BFG muds/ crapload more.
MY THEORY OF PERPETUAL SPENDING: if i've built my drivetrain strong enough to where i can't break it anymore, i clearly don't have enough power. Strokin' is in the future.
bigrobby is offline
post #2 of 14 Old 02-23-2009, 03:37 PM
jgillespie
the highest amount i've seen was boring .030 over.
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
post #3 of 14 Old 02-23-2009, 03:44 PM
Chris
Guy with jeep
Chris's Avatar
I am at .040 now and no issues of any type. When I was talking to my machine guy he said he could do more but didn't recomend it.
Chris is offline
post #4 of 14 Old 02-23-2009, 04:24 PM Thread Starter
bigrobby
do either of you have the 4.2? i thought your years had 4.0's.....which is actually whats in my other jeep. the 4.0 has a much bigger bore to begin with....and i suspect since the block is very similar that the 4.2 has more meat to bore out.
a 4.2 bored .060 will still not be as big of a bore as a stock 4.0.
bigrobby is offline
post #5 of 14 Old 02-23-2009, 04:45 PM
Chris
Guy with jeep
Chris's Avatar
I have the 4.0, I didn't know they were much different. I would just call a couple machine shops and see what they say.
Chris is offline
post #6 of 14 Old 02-23-2009, 06:45 PM
RoverJeep90
I don't know if it means anything, but I went 0.060 over on mine. Guy at the shop did it with no worries. Granted, mine is a 4 cyl, but if you're asking if it's out there, then yes. Check a Haynes manual for the actual specs on your motor, then calculate a percentage increase for the bore. With your numbers, talk to the dealer, as they might be able to pull up some stress specs for your block and possibly check your figures.
1990 Red YJ 2.54 L (Rebuilt) 5 Speed with 94 rollbar | Dynomax Exhaust | Luk Clutch
2.5" Old Man Emu over 31x10.50 BFG MTs on 15x8 AR 767s | 1" Daystar Body Lift
Two Tops | Full and Half Doors | KC Daylighters | Hella 5500 | OME Steering Stabiliser
Sony CDX-GT300 | Kicker ZX500.1 | Kicker ZX350.4 | Kicker ZX200.2 | Kicker L5 Solobaric Sub | Kicker 6x9's | Apline 6.5's | Boston 4x6's
Truckstop CB Antenna | Class 3 Hitch
RoverJeep90 is offline
post #7 of 14 Old 02-23-2009, 08:44 PM
shaggyjim
shaggyjim's Avatar
Check this out it might help....http://www.jeepstrokers.com/forum/
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #8 of 14 Old 02-24-2009, 08:25 AM
wendell
1987 YJ Wrangler
I didn't have mine bored, but did add a holley 470 4 barrel, offy intake, comp cam, header, HEI and MSD. "wow", what a difference. This summer it's getting a 4.0 head from clearwater and rollor rockers. I don't know what other plans you have for your 258, but they will make some power with the right parts.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #9 of 14 Old 02-24-2009, 02:05 PM
jsawduste
2006 YJ Wrangler
did .080 on my 93 block 4.0 stroker build. But why .060 ? is the block that worn to need it ?
jsawduste is offline
post #10 of 14 Old 02-24-2009, 02:08 PM Thread Starter
bigrobby
we've already got the MPI for the 4.0... we're putting in a 4.0 High output head, header, exhaust, intake, head ported and milled. slight decking of the block. Crane cam 753901 (have that in my 4.0...awesome cam!) even goin to the stock 4.0 cam would be a big difference but we're goin all out.
and if we bore it .060 it will be close to a 4.4 liter. with all the 4.0 goodies and performance cam.
now my 4.0 with all the goodies is very strong. using our best dyno flywheel recalculations my 4.0 is running around 265 ft/lb torque and 230 hp. even 4 inches up and 33's that jeep DESTROYS stock 4.0's every time i pull up next to one. I'm expecting this build to be quite a bit stronger
bigrobby is offline
post #11 of 14 Old 02-24-2009, 02:11 PM Thread Starter
bigrobby
no .060 just to add a little displacement. on one hand the difference in displacement between that and say .030 overbored may not be noticeable......on the other hand...if it's as safe to go .060 as i think it is......then why not?
bigrobby is offline
post #12 of 14 Old 02-24-2009, 07:49 PM
jsawduste
2006 YJ Wrangler
Well you will unshroud the valves a touch. But not enough to make much difference. Simply have the block sonic checked to see how much meat is in it.
post #13 of 14 Old 02-25-2009, 12:22 PM Thread Starter
bigrobby
if anyone's interested i got a real answer from a guy who used to race them. as i suspected...boring the 4.0 has its limits....they try not to push it too much for motors built to run hard
however ...the 4.2 DOES have quite a bit of meat in the cylinder walls. he said on racing motors, they'd bore them .080 or .100....keep in mind those motors were under tremendous heat and stress.
i'll be going with .060 for one simple reason....going any bigger will take custom pistons which i dont wanna pay for.
bigrobby is offline
post #14 of 14 Old 02-25-2009, 05:40 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Going .060" over can always be a possible cause for problems in any motor. The biggest problem is what they call "core shift". When the sand castings for the engines are made and them assembled the happy worker in the foundry may not always align the sand core casting for the cylinders centered perfectly in the block sand casting. So when the metal is poured the cylinder walls, (inner water jackets) are not all the same thickness. If they are off centered then you will have a vertical section of each wall that is thinner than the rest of each cylinder. So when you punch that bad boy out 060" you can end up with a motor that has cylinder walls that have no meat left in them in one section.
They can test a block for core shift using sound I beleive. I forget the name of the test or the name of the tool they do it with. It is worth the money in my opinion. IF your machinist does not know what core shift is....find another machinist.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is online now
