.060 over - JeepForum.com
post #1 of 10 Old 06-17-2010, 08:17 PM Thread Starter
yjmikea
.060 over
has anybody out there gone .060 over on a 4.2 and had no problems running it hard after wards or such i just get a new motor thanks
yjmikea is offline
post #2 of 10 Old 06-17-2010, 08:27 PM
plym49
I have no experience going .060 over on a 258.
However, my personal guideline on overboring is that, unless the engine is question is known to have thick-wall castings that can accept overbores of .060 and above, if I need to go bigger than .030 over, I sleeve the cylinders back down to standard.
plym49 is offline
post #3 of 10 Old 06-17-2010, 11:47 PM
BlackRhino
BlackRhino's Avatar
I wouldn't imagine having any problems going .060 over. The 4.2L isn't exactly a high compression engine. I had my 2.5L bored .060, it was worn out by .045 as it was.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #4 of 10 Old 06-17-2010, 11:52 PM
YJake
Did that extra compression turn the squirrels into prairie dogs?
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #5 of 10 Old 06-18-2010, 12:06 AM
BlackRhino
BlackRhino's Avatar
Jake
lol. The .060 bore made absolutely no difference in terms of power
I only did it because the cylinders were already worn by .045
post #6 of 10 Old 06-19-2010, 09:01 PM
Castr8r
.060 overbore is OK. If you want to go further than that, it's a crapshoot. I've read of going .120 over sucessfully, but you need to have a spare block on hand. You can bore it all you dare to and it won't raise compression one bit. Compression is raised by shaving the heads or milling the top of the block.
Castr8r is offline
post #7 of 10 Old 06-19-2010, 11:23 PM
boyce1911
1977 FSJ Wagoneer
My 4.2 is .060 over and Ive got almost 200 miles on it. I know its probably not long enough to tell yet but so far no issues. We'll see this summer if Im going to have temp problems.
boyce1911 is offline
post #8 of 10 Old 06-21-2010, 07:42 PM Thread Starter
yjmikea
thanks guys im still on the fence weather to rebuild the 4.2 or go for a 3.8 or 4.3 gms but there running high in the dollar department ????
yjmikea is offline
post #9 of 10 Old 06-21-2010, 09:00 PM
RoverJeep90
I rebuilt my 4 cylinder in my 1990 and went 0.060 over and have had no problems so far. Based on others have said, I'm guessing that it'll be just fine. Personally I'd say just go with rebuilding what you've got. If I were faced with the decision again, I'd upgrade to a 6 cylinder, but I'd still rebuild all of it anyways. So, to me it boils down to whatever work you want to do after the rebuild. I'd rather just put it all back together knowing it was new than have to weld new mounts and fish through wiring. But then again I can't weld, so that probably has something to do with it. Either way, you'll be happier in the end with the new motor!
1990 Red YJ 2.54 L (Rebuilt) 5 Speed with 94 rollbar | Dynomax Exhaust | Luk Clutch
2.5" Old Man Emu over 31x10.50 BFG MTs on 15x8 AR 767s | 1" Daystar Body Lift
Two Tops | Full and Half Doors | KC Daylighters | Hella 5500 | OME Steering Stabiliser
Sony CDX-GT300 | Kicker ZX500.1 | Kicker ZX350.4 | Kicker ZX200.2 | Kicker L5 Solobaric Sub | Kicker 6x9's | Apline 6.5's | Boston 4x6's
Truckstop CB Antenna | Class 3 Hitch
RoverJeep90 is offline
post #10 of 10 Old 06-22-2010, 09:33 AM
bilwil
1987 YJ Wrangler
Mine came with a mopar rebuild with 90,000 on it. semes they were all .040 over and .010/.010. Next motor will be 4.6
Bill,
87, Laredo
bilwil is offline
