06 TJ Booster & MC in my YJ - Page 3 - JeepForum.com
post #31 of 39 Old 04-05-2013, 02:46 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Originally Posted by JeeperDon View Post
Thanks. I wish I knew exactly what the length is of the rod in my '93, and the hole diameter. I'd like to work on getting the new one ready without pulling the old one out of the Jeep just yet, rather just have the new one ready to go on swap day.
My 87 had a 5/8 hole diameter.
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #32 of 39 Old 04-05-2013, 04:04 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Originally Posted by Que89YJ View Post
the stock 93 booster?
Yes, I'm coming from a '93. None of the local auto parts have a replacement '93 in stock, was hoping to look at it and measure, trace the rod hole end to ensure the right hole size and outside shape (for switch compatibility).
I guess I could just wait and not be anxious. I could actually cut the rod end off the old one and use it with the bolt for the new one, duh.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #33 of 39 Old 04-05-2013, 04:23 PM
Que89YJ
I am going to fiberglass and I am going to have to do the swap and deal with the rod length too. I was going to use the old one with threads and a insert in the middle like I saw on the one booster swap.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #34 of 39 Old 04-07-2013, 02:01 PM
JeeperDon
JeeperDon's Avatar
Holy Frelling Moly! I left skid marks... the first ones in a dozen years! I didn't hesitate to weld the hex sleeve to the boster shaft. I just put a narrow piece of tape on the shaft near the booster, and a vice grip in front of that on the shaft to absorb heat. The tape never showed signs of heat after the welding.
Web Admin for
post #35 of 39 Old 04-07-2013, 03:54 PM
flcracker
Willing to bet the wife would argue the no skid marks comment but I digress....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #36 of 39 Old 04-07-2013, 08:41 PM
czjeeper
Question:
Could you thread the rod and then use a union, instead of welding?
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #37 of 39 Old 04-08-2013, 05:27 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Originally Posted by czjeeper View Post
Question:
the rod is exactly .500" so you will need a die to fit that. I tried my 1/2" die but i couldnt get it started.
March 2017 YJOTM
87TPIYJ is offline
post #38 of 39 Old 04-08-2013, 06:50 AM
JeeperDon
JeeperDon's Avatar
Question: Could you thread the rod and then use a union, instead of welding?
Don't worry about the welding, unless you don't weld, then worry about it a lot.
Not having a welder means you are perpetually figuring out the 2nd-best way to do almost every Jeep project.
Web Admin for
post #39 of 39 Old 04-08-2013, 10:19 AM
czjeeper
That pretty much sums me up!
US Army combat vet
czjeeper is offline
95 M/C Booster Write-UP Double_DD-s YJ Wrangler Technical Forum 2 12-30-2009 12:57 PM
'95 XJ M/C & Booster timatoe YJ Wrangler Technical Forum 7 11-27-2008 10:30 AM
97 TJ Booster into 92 YJ djfred YJ Wrangler Technical Forum 5 04-14-2008 04:48 PM
Brake Booster ionakana YJ Wrangler Technical Forum 1 09-28-2006 08:08 AM
Brake Booster?? CarsonKetrowYJ YJ Wrangler Technical Forum 2 07-10-2006 09:07 AM
