02 sensor wire harness? - JeepForum.com
post #1 of 11 Old 08-11-2011, 10:17 AM Thread Starter
Matt24138
Ok I replaced my 02 finally passed emissions. Now my problem is it runs like crap until it warms up. I have reset the ECM 6 times. I had a broken wire on the harness that I repaired with solder and a shrink tube. My understanding is the 02 has a heating element that kicks in until operating temp. Anyone know which wire this is. I checked Haynes with no luck. I assume the broken wire was to the element causing my cold running issue and I need to repair my repair maybe cut it back further for a cleaner connection.
Matt24138 is offline
post #2 of 11 Old 08-11-2011, 10:29 AM
oldtime_ironman
My haynes manual shows the gray and yellow wires are for the heater, and a black wire up the middle is for the actual sensor (2.5L, the 4.o similar)
oldtime_ironman is offline
post #3 of 11 Old 08-11-2011, 10:37 AM Thread Starter
Matt24138
I have 4 wires
post #4 of 11 Old 08-11-2011, 10:45 AM
oldtime_ironman
Originally Posted by Matt24138 View Post
I have 4 wires
My mistake - I dug out the 4.0 diagram. It seems the sense wires on the 4.0 are on pins 1 and 2 in the connector. They should be a gray, and a brown/red. The heater wires therefore would be on pins 3 and 4 in the connector. It says those are black and dark green/black.
The sense wires go directly to the ECU. The heater wires go to the ASD relay and a big junction splice.
post #5 of 11 Old 08-11-2011, 10:51 AM Thread Starter
Matt24138
Ok thanks so much! Now I can figure out my rough start up issue. I am 99% it's the heater not working.
post #6 of 11 Old 08-11-2011, 10:52 AM
Que89YJ
If its running like crap until it warms up its probably not your O2 sensor. It doesnt start to get used until its warmed up and in closed loop. Since its starting out bad cold I would check the engine temp sensor.
Que89YJ is offline
post #7 of 11 Old 08-11-2011, 11:40 AM Thread Starter
Matt24138
It all started when I replaced it. From what I can gather the heating element tells the ECM to use a pre programmed map until it is at temp. If I unplug the 02 the issue stops. So I think with the wire not having a good connection it is telling the ECM that it is heated so it is trying to run the air/fuel mix as if it was warm.
post #8 of 11 Old 08-11-2011, 12:29 PM
Que89YJ
It will not read the O2 sensor until the engine is warm enough to go into closed loop. Try this senario, the temp sensor is telling the ecm to read the O2 sensor when the engine isn't warm enough so disconnecting the O2 sensor forces it into a default cailbration. Check the temp sensor.
Que89YJ is offline
post #9 of 11 Old 08-11-2011, 12:38 PM Thread Starter
Matt24138
I will check it out.
post #10 of 11 Old 08-11-2011, 12:42 PM Thread Starter
Matt24138
Any tips for diagnosing it? I know my temp gauge reads correctly. Is it something I can clean?
post #11 of 11 Old 08-11-2011, 12:49 PM
Que89YJ
Its a different temp sensor. Our Jeeps have 2. 1 for the guage on the rear and the one for the engine in the front by the thermostat housing.
Here is the resistance readings to check it.
http://www.jeepforum.com/forum/f12/u...38/index2.html
Que89YJ is offline
tow wire harness help bbqfreak TJ Wrangler Technical Forum 11 03-09-2011 05:59 AM
speed sensor wire and reverse wire for aftermarket navigation system Stacydmcc JK Wrangler Technical Forum 1 11-06-2009 03:07 PM
O2 sensor wire harness / What Octane do you run? xamdarb TJ Wrangler Technical Forum 7 05-18-2009 01:27 AM
battery wire harness green wire? brinoff YJ Wrangler Technical Forum 4 03-07-2009 04:25 PM
02 Sensor Wire Harness OneLung YJ Wrangler Technical Forum 1 12-03-2007 07:10 AM
