KL Liberty/Cherokee - JeepForum.com
post #1 of 31 Old 05-02-2011, 12:54 PM Thread Starter
XJ2Timer
KL Liberty/Cherokee
A replacement for the Cherokee medium SUV, called the Liberty in the United States, that will go into production in the United States in early 2013 and will be exported to Europe by spring 2013. The SUV will use a 170-hp, 2.0-liter four-cylinder gasoline engine.
http://www.autonews.com/apps/pbcs.dl...#ixzz1LCOUDEQK
Seems like the Cherokee name could return to North America too. It will be sad to see the Cherokee name on something like this. It needs at least a small Pentastar V6 instead of a 2.0 4 cylinder.
1st one- 1989 Cherokee Laredo. 12 great years
2nd one- 2001 Cherokee Limited. Got it before they were gone.
XJ2Timer is offline
post #2 of 31 Old 05-02-2011, 04:58 PM
Jcool
1993 XJ Cherokee
will be interesting to see what they come up with
also curious about the following
Jeep's first small SUV, a Fiat-based "baby" Wrangler that may be built in Toluca, Mexico, for sale in Europe, North America and Latin America starting in late 2013 or early 2014.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_) 1993 Jeep Cherokee Sport 4.0L
Jcool is offline
post #3 of 31 Old 05-02-2011, 08:00 PM Thread Starter
XJ2Timer
And the Patriot/Compass replacement gets built in Italy. America is really going to go for Jeeps made in Mexico and Italy.
I guess I ought to change that. Jeep fans are really going to go for foreign made Jeeps.
XJ2Timer is offline
post #4 of 31 Old 05-05-2011, 06:02 PM
winkosmosis
Car based? Damnit...
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #5 of 31 Old 05-07-2011, 04:35 PM
Marauder_Pilot
Marauder_Pilot's Avatar
Every Jeep after the SJ Wagoneers/Gladiators save the CJ/Wrangler has been 'car-based'. Your XJ is 'car-based'.
All 'car-based' means is unibody.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is online now
post #6 of 31 Old 05-07-2011, 08:35 PM
AMCSportTruck
1988 MJ Comanche
The XJ is actually car based 100% its plate form came from the AMC Eagle's IIRC it was the wagon's chassie . . . The SX/4 has D30 IFS front end not sure about the Wagons . . .
Mike
1953 Studebaker M275 / 1962 GMC 4500 / 1969 AMC AMX-390 / 1977 Ford F350 / 1982 AM-Eagle SX/290 .
1982 AM-Jeep J-5500 / 1988 AM-Jeep MJ-343 / 1992 GTA Trans AM / 2007 Honda Rubicon.
AMCSportTruck is offline
post #7 of 31 Old 05-08-2011, 07:48 PM Thread Starter
XJ2Timer
By that flawed logic every body on frame car is "truck-based".
I would describe it as any CUV or SUV that had a passenger cars platform as the starting point of its design.
By that definition only the Patriot and Compass could be considered car based as they were designed alongside the Dodge Caliber.
There were never any passenger car versions of the XJ, ZJ, WJ or WK.
But the new Liberty (rumor is the Cherokee name will be used here too), the Patriot/Compass replacement and the new B sized Jeep will be car based as they use a Fiat passenger car platform as a starting point.
XJ2Timer is offline
post #8 of 31 Old 05-08-2011, 10:44 PM
Marauder_Pilot
You're right, and also missing the point completely.
The Cherokee is no more a car than the Patriot is, and my Wrangler or my old Crown Victoria aren't trucks by any estimation.
The point is that unibody is not an automatic curse. Plus, there was a car of the Cherokee in a sense-it shares as much with the old AMC Eagle, which itself was a stretched Gremlin with a CJ transfer case as the Patriot does with the Caliber.
A platform is nothing more than a set of dimensions. You don't have to share a single part between them. The Ford Explorer and Taurus share a platform, yet the Explorer is still a fairly capable vehicle off-road-it's no Grand Cherokee, but it's easily the equivalent of the Durango, despite being 'car-based'.
-TTAC
post #9 of 31 Old 05-09-2011, 02:32 PM Thread Starter
XJ2Timer
Y
The worry is that Fiat parts will be used by Jeep.
XJ2Timer is offline
post #10 of 31 Old 05-13-2011, 03:08 AM
winkosmosis
The Fiat Panda is 100% car though. It has zero truck characteristics.
post #11 of 31 Old 06-05-2011, 08:30 AM
Joenavy85
2005 KJ Liberty
at least they mention only ONE SUV to replace the patriot and compass, that will at least lower the number of cars that "Jeep" will be producing. Jeep is in quotes due to the obvious outsourcing that Chrysler is doing by building them outside this country
Joenavy85 is offline
post #12 of 31 Old 06-06-2011, 02:20 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The XJ Cherokee was a brand new vehicle designed by Jeep and Renault to be an SUV from the start. It was one of the first Computer Aided Design (CAD) vehicles and was the first Jeep with a ladder-boxed chassis integrated into a single monocoque unit body (unibody) rather than the traditional separate body-on-frame construction. It shared next to nothing with the AMC Eagle besides an updated version of the in-line six cylinder Jeep 4.0L 242 CI I6 RENIX FI motor starting in 1987, and a leaf spring mounted D35 solid axle.
The XJ does have a "frame", but it is Unibody construction. It has solid front and rear axles and a high/low shift on the fly transfer case.
Early AMC 1980's Eagles were full-time, all-wheel drive cars. A few years later a switchable 2wd/4wd system was introduced, but shifting between those modes required the Eagle to be fully stopped and it had no low range. "Shift-on-the-Fly" capability was added to the Select Drive 4-wheel-drive system as standard equipment in 1985.
CJ7-Tim is offline
post #13 of 31 Old 06-07-2011, 10:35 AM Thread Starter
XJ2Timer
An anonymous source told us that the next-generation Jeep Liberty will move far upscale of the current model
http://www.allpar.com/news/index.php...o-move-upscale
XJ2Timer is offline
post #14 of 31 Old 06-07-2011, 12:16 PM
bluefever
just what I've always wanted a more expensive soccer mom mobile that utterly disgraces the nameplate on it
bluefever is offline
post #15 of 31 Old 06-07-2011, 12:19 PM
bluefever
I wonder if that means they sprung for as much as there already paying for halfshalfs when they move production down to mexico like there so rumored to be moving production down to,maybe that means driving on a dirt road might not void the warranty on the drivetrain,lmfao
Is it true the Liberty is being discontinued? KDOG2008 Future Models & Prototype Discussion 8 02-21-2011 07:48 PM
2010 Liberty Renegade Gramps Future Models & Prototype Discussion 13 10-03-2010 10:59 PM
Liberty + Comanche = Libermanche gabriel05 Future Models & Prototype Discussion 34 08-25-2010 10:27 AM
Possible Alfa-Romeo SUV based on Liberty XJ2Timer Future Models & Prototype Discussion 0 06-19-2009 09:00 AM
2008 Liberty KK details mkfx35 Future Models & Prototype Discussion 36 11-15-2008 10:37 AM
