Jeep Liberty redesigned for '13, Patriot/Compass get axed, Grand Wagoneer (Commander) - Page 2 - JeepForum.com
post #16 of 25 Old 08-26-2011, 12:52 PM
Pathkiller
1974 CJ5
Originally Posted by Marauder_Pilot View Post
Exactly. The Grand Wagoneer was only a hardcore off-roader by association. At the time, independent suspension on trucks just flat out did not exist. Independent suspension on trucks didn't start showing up until the late '80s and early '90s, and even then it took until the mid '90s for it to become commonplace.
It had solid axles because that's what was available at the time. It wasn't designed to be a rock crawler, it just happened to be one because it was made by digging around in Jeep's parts bin to make a luxury SUV.
Except that the first Wagoneer offered IFS as an option when it debuted in 1963, the first American 4x4 to have IFS. http://hooniverse.com/2011/06/05/hoo...nt-suspension/
Which makes pretty much everything you said about IFS irrelevant.
Pathkiller is offline
post #17 of 25 Old 08-27-2011, 01:42 PM
BadAsh74
I knew the Waggy and Gladiator were the first American 4x4s with IFS, but Id never seen a picture of the setup. Thats VERY similar to the TTB setup that Ford had. And for the record, I think that this type of system is better than the A-arm/Wishbone setups that most mfg's favor. This is a solid axle that happens to have a pivot in the center, whereas the more commonplace IFS systems with their CV joints arent much different than what you'd find on a fwd car.
BadAsh74 is offline
post #18 of 25 Old 08-27-2011, 01:52 PM
austinaubinoe
Was just gonna say the same thing! The wagoneer was way ahead of the times all the way to the early 80's, then it went stagnate when they decided to not step up to Fuel Injection or even a solid state coil.
I daily drive my 91 and that air actuated 4x4 switch is just awesome. Now push button 4x4 is commonplace!
austinaubinoe is offline
post #19 of 25 Old 08-28-2011, 09:57 AM
Jeepsman
2005 KJ Liberty
I've always known that the had a IFS Wagoneer but I have never seen any pictures of it. I wonder how many of those still exists?
2005 Jeep Liberty
2006 Jeep Wrangler X (SnowWhite's)
Jeepsman is offline
post #20 of 25 Old 09-16-2011, 09:41 PM
Condor1970
Wait a minute!!!
They are going to make the new Liberty AWD?
And they are putting it on a Fiat frame?
Ok, is the Fiat frame going to be a stronger/better off-road capable uni-frame?
And, why would they get rid of the Dana-35/30 combo? That has been a staple of the Cherokee/Liberty line-up for decades. They are perfect for off-roading, and upgrading with LS or lockers for serious users.
or, are they still going to use the Dana-35/30?
Will the 2013 Liberty still be as capable?
Condor1970 is offline
post #21 of 25 Old 09-16-2011, 10:27 PM
Marauder_Pilot
Marauder_Pilot's Avatar
Uhhh...you DO know that the current Liberty is IFS, and uses a Chrysler 8.25 rear axle, right?
But, yes, it's going to be on a Fiat-derived PLATFORM (Not a frame, a platform is just a set of dimensions for manufacturing purposes), and will likely be AWD.
The KK and KJ Libertys (Liberties?) aren't all that capable. Substantially less so than the XJ. It's going to be moving upmarket-think of the smaller Land Rovers, in terms of capability and features.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
post #22 of 25 Old 09-16-2011, 10:42 PM
Condor1970
So, it is going to be better then?
I hope so. I'm sorry, I was thinking of my old 1991 cherokee which had the Dana-35 in the rear.
I sure hope they will be upgradable to use DTT's in the diffs. I want something still somewhat affordable that I can do some good off-roading with.
post #23 of 25 Old 09-16-2011, 10:51 PM
Marauder_Pilot
Then you'll be buying a Wrangler-the next Liberty will probably be reasonably competent off-road but upmarket enough that you won't want to. It'll basically be a smaller companion to the new Grand Cherokee.
-TTAC
post #24 of 25 Old 09-17-2011, 02:25 AM
Poncherello
2010 KK Liberty
I been reading this thread and I remember that Fiat did want to make lighter bodies, transmissions with more gears (good so long as they are reliable), and reintroducing turbo diesels which would be awesome. And even if everything really isn't designed on what we like the most important is that more Americans will be employed right?
Anyways, as far as off road capable SUV's you can't forget they are about the Pathfinders, 4 Runners, FJ Cruisers, Xterras and each of them are very capable they have power gearing and ground clearance. And real nice even though I can't afford any of them LOL
Just a last note, how you can say that KK or KJ isn't capable? I beg to differ, I think the Lib pretty capable, it could use more ground clearance which is a biggy but it is capable. I've had it the snow, sand & water (12-16") and no issues and admit it was nothing hardcore and won't be until I pay it off (3yrs 11 months and counting). The darn hood alone weighs about 90lbs and is all steel I could sit up on it and stare at the stars without buckling, now how many vehicles built today can do that?
Well I guess we can all hope and pray and in the meantime just do some jeeping :]
Poncherello is offline
post #25 of 25 Old 09-17-2011, 07:21 AM
Condor1970
Ok, so the current Lib has a Chrysler diff in the rear, but it can be upgraded.
What is in the newer IFS front?
Can it be upgraded with an LS diff?
2014 Grand Wagoneer Sarge_ Future Models & Prototype Discussion 64 10-25-2012 10:47 PM
New Grand Wagoneer ? ! ? ! ? whats up ? ! ? ! ? AMCSportTruck Future Models & Prototype Discussion 36 07-31-2011 03:18 PM
2011 Jeep Compass is a baby Grand! WJ Freak Future Models & Prototype Discussion 41 02-27-2011 12:03 PM
new grand wagoneer? jos88gw Future Models & Prototype Discussion 45 10-29-2009 07:06 AM
Jeep Patriot EV - Detroit Auto Show table Future Models & Prototype Discussion 0 01-13-2009 08:53 AM
