zj tie rod swap - JeepForum.com
post #1 of 7 Old 07-14-2010, 10:22 AM Thread Starter
XGoBoomJ
1997 XJ Cherokee
zj tie rod swap
I am in need of an alignment but before i do that I have heard that I can get a v8 ZJ tie rod and its bigger and also a direct swap. on a 97 xj sport.
Does anyone know info about this?
Or if anyone knows of a write up how to remove/replace a tie rod.
I am the Stormtrooper..
XGoBoomJ is offline
post #2 of 7 Old 07-14-2010, 10:35 AM
jk_surgeonfish
Do a search on the forum for this. I did it and it worked great. There are several write-ups with part numbers if you search or Google it. I picked up my parts at Napa and the upgrade is worthwhile.
jk_surgeonfish is offline
post #3 of 7 Old 07-14-2010, 10:43 AM Thread Starter
XGoBoomJ
1997 XJ Cherokee
the search isnt very friendly with me today..
I cant even find how to REMOVE the tie rod.
I simply want to remove it and replace it with a zj tie rod and then get an alignment..
XGoBoomJ is offline
post #4 of 7 Old 07-14-2010, 06:09 PM
trs80
Yes, it works. Just did the swap over the weekend.
I used parts from a 1996 Grand Cherokee with the V8. Get the right inner TRE, adjusting sleeve, and left outer TRE. Got the three parts from Autozone for under $70.
The stock piece is easy to remove, just take a look at it. Its only two TRE and its free.
trs80 is offline
post #5 of 7 Old 07-14-2010, 09:38 PM
pentastar01
How to remove a tie rod...
BIG
F****N
HAMMER
Life's tough, that's why I drive a Jeep. Until it breaks, then life's a *****.
pentastar01 is offline
post #6 of 7 Old 07-14-2010, 10:01 PM
Dead_End
1990 XJ Cherokee
pulled one out of the junkyard for $20 for the TJ, and I'm buying the parts for the XJ. Much stronger than the stock tie rod.
[/Kevin]
_____________________________________________
Jurassic Park '90 XJ, '00 TJ
Dead_End is offline
post #7 of 7 Old 07-14-2010, 10:05 PM
Holder350
1995 XJ Cherokee
I ended up removing a stock xj tie rod, and sleeving it with a piece of tubing, and welding it to the tie rod.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
np207 swap info needed for 2.8 v6 np231 dirrect swap? robdoggydog1 XJ Cherokee Technical Forum 6 01-26-2014 09:42 PM
Tranny swap ?s: AW4 to AX15 swap (or any other trannies for that matter)... Bryson XJ Cherokee Technical Forum 8 06-22-2009 02:01 AM
98 ZJ 4.0 swap into a '96 XJ. .....direct swap? possible probs? 4.0H.O.XJ XJ Cherokee Technical Forum 6 09-12-2008 07:57 AM
Cluster swap for '98 XJ... direct swap? TheDon427 XJ Cherokee Technical Forum 4 09-10-2007 07:49 PM
which to swap 2.8 with scrodom1977 XJ Cherokee Technical Forum 1 02-25-2007 07:55 AM
