zj steering swap - Page 2 - JeepForum.com
post #16 of 20 Old 05-17-2013, 08:02 AM
egodfrey
egodfrey's Avatar
I cannot add anymore to that response it was pretty much perfect Mwildman nailed it on the head.
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #17 of 20 Old 05-17-2013, 08:56 AM
Mwildmann
Thanks for the props, egodfrey!
Mwildmann is offline
post #18 of 20 Old 05-17-2013, 10:34 AM
egodfrey
egodfrey's Avatar
I have never run a v8 tie rod but I believe they are not just a straight piece, I believe they have some shape from the factory. I'm sure ill be corrected if I'm wrong but I believe they look different from a xj one so don't freak out.
Like I said they I have never run one so someone correct me if I'm wrong
egodfrey is offline
post #19 of 20 Old 05-17-2013, 10:47 AM
Mwildmann
You're absolutely right. They are bent down in the center, sort of like a wide, flat, goofy smile.
post #20 of 20 Old 05-17-2013, 03:57 PM
StreckXJ
2009 WK
This is a photo of a TJ but it essentially the same for the XJ. The V8 ZJ tie rod has a slight bent around the front gearbox but is much thicker and stronger than the XJ.
Daniel
2009 WK Laredo QTII
Formerly: 2001 XJ, 200k+ miles.
StreckXJ is offline
