zj steering swap - JeepForum.com
post #1 of 20 Old 05-15-2013, 05:55 AM Thread Starter
yamazinger
1993 XJ Cherokee
zj steering swap
been looking into doing a junkyard upgrade to the zj tierod and draglink. i barely do any offroading anymore due to there being nowhere to go that's close so this setup wont be worked too hard. This is a direct bolt in correct? also i have a 5in lift and just put on an adj track bar. Ive heard about getting zj pitman arms to drop the steering down so its parallel. Is this necessary with the adj track bar or that is something you could do if you didnt have an adj track bar?
yamazinger is offline
post #2 of 20 Old 05-15-2013, 10:31 AM
Mwildmann
You only need the V8 ZJ tie rod. The drag links are the same between ZJs and XJs. You should get a drop pitman arm if the frame side of the track bar has been lowered. The drag link and track bar should be as parallel as possible. Post a pic of the front suspension/steering and we'll probably be able to tell you if you need a drop pitman arm or not.
Mwildmann is offline
post #3 of 20 Old 05-15-2013, 12:30 PM
egodfrey
egodfrey's Avatar
Basically the drag link and the trac bar need to be at roughly the same angle, or you will get bump steer.
X2 on posting pics
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #4 of 20 Old 05-16-2013, 06:22 AM Thread Starter
yamazinger
1993 XJ Cherokee
thanks -that answered everything i needed to know. also i was just thinking, the straight bar that attaches from tierod to the draglink, would it be worth rigging up a stronger setup as in just some beefier round tubing and tap the ends for the tie rods and use a nut to secure the tie rods? or is it better not to mess with the steering components?
post #5 of 20 Old 05-16-2013, 06:30 AM
Mwildmann
Which component are you asking about? Steering components consist of a drag link and a tie rod with rod ends at the junctions. The drag link goes from the steering box and connects to the tie rod near the passenger side knuckle. The tie rod runs between the knuckles. You originally asked about the V8 ZJ upgrade, and what that gets you is a real beefy tie rod. What "straight bar that attaches from the tierod to the draglink"?
post #6 of 20 Old 05-16-2013, 08:12 AM
egodfrey
egodfrey's Avatar
In confused there as well.
egodfrey is offline
post #7 of 20 Old 05-16-2013, 09:42 AM
DriverX
The straight bar he is referring to is the tie rod. It attaches from the driver side knuckle to the drag link. A ZJ tie rod replaces that with a solid bar, adjuster sleeve and tie rod end.
The drag link goes from the pitman arm to the passenger knuckle.
The drag link is the same for the ZJ and XJ.
DriverX is offline
post #8 of 20 Old 05-16-2013, 09:51 AM
egodfrey
egodfrey's Avatar
The way he explained it was there was some bar that went from tie rod to drag link. Well that doesn't exist. I assumed he has a typo in there somewhere.
egodfrey is offline
post #9 of 20 Old 05-16-2013, 09:55 AM
Mwildmann
That's true, I was slightly incorrect with my previous description. But the question still doesn't make sense relative to what was discussed before about the V8 ZJ tie rod.
post #10 of 20 Old 05-16-2013, 10:08 AM
DriverX
What question? About it being a direct bolt in? Or about messing with steering components?
The ZJ tie rod is a direct bolt on part. Make sure you get the tie rod end and adjuster sleeve too (a complete tie rod from knuckle to drag link).
I'm not sure what he meant by "mesing with steering components". That is a very vague question.
I'm confused now too...
DriverX is offline
post #11 of 20 Old 05-16-2013, 10:11 AM
Mwildmann
This question. "The straight bar that attaches from tierod to the drag link..."
post #12 of 20 Old 05-16-2013, 10:13 AM
DriverX
I see... I have no idea what he is referring to either. I think it was a typo on his side.
DriverX is offline
post #13 of 20 Old 05-16-2013, 11:10 AM
egodfrey
egodfrey's Avatar
That's the only part that has me confused
egodfrey is offline
post #14 of 20 Old 05-17-2013, 02:11 AM Thread Starter
yamazinger
1993 XJ Cherokee
sry about the confusion, what my question was, is the tierod end that connects to the drivers side knuckle and threads into the "straight bar" that runs parallel to the differential and connects to the drag link using another tie rod end threaded into the same bar. I assumed that when i was told all i needed was the tie rod, that meant just the tie rod end that connects on the drivers side. So when i steal this setup off a zj i need entire thing? just a misunderstanding on my end
post #15 of 20 Old 05-17-2013, 04:41 AM
Mwildmann
That makes more sense. The "straight bar" is the tie rod. Like what was said previously, the V8 ZJ tie rod only has adjustment at one end (as in only one replaceable tie rod end, the other tie rod end is integral to the tie rod itself). So, from the donor ZJ, you'll need the tie rod, tie rod end and the adjuster sleeve and long with the hardware. You'll completely understand when you see it. Be sure that you're getting one from a V8 ZJ, I think that the 4.0L ZJs use the same tie rod as an XJ.
