ZJ Rear Seat Headrests Installed With Writeup! - Page 2 - JeepForum.com
post #16 of 21 Old 08-04-2013, 08:46 PM
ECL
For what it's worth, I bought the rear seat back from a Grand, ripped it open and removed the rear headrest brackets by cutting the welds with a grinder. I then removed and opened up the seat back from my Cherokee and bolted the brackets to the metal seat back pan. I had to make up some custom spacer blocks out of wood to allow the brackets to sit nice. I bolted it together using self locking nuts (nylon inserts) so they won't rattle free. I cut back the foam a little so the cushion would lay nice.
Will it hold up in an accident? I don't know but it has to be better than not having it. Even if it gives way, it will have taken some of the force of the acident.
In hindsight, the only thing I'd do differently would be to spend more time on the spacer blocks. My blocks are flat which means the headrests come out of the setback parallel to the seat. Ideally, they'd pitch forward a bit to be closer to your head.
EVERYONE should do this mod!!
ECL is offline
post #17 of 21 Old 08-17-2013, 10:01 AM
lazyxj
Here is another possibility for adding headrests to the rear seats
http://jeep-xj.info/HowtoHeadRests.htm
2001 Sport, 4" lift, 33 X 10.50 KOs, R.E. DB, R.E.-UCA, JKS-LCA, ACOS, 8.25-4.56-TruTrac, SYE, D-30 E-locker w/alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Lots of armor, Towing baseplate.
lazyxj is offline
post #18 of 21 Old 09-01-2013, 10:54 AM
jilly44
Success!!
I did it with my friend assisting along the way. I now have headrests and they look great. No photos now but I'm excited!! I put some cup holders in as well and now I need to address the rust in my 'new' vehicle. Thanks all! Cheers........
jilly44 is offline
post #19 of 21 Old 09-01-2013, 10:58 AM
jilly44
Originally Posted by TPI Monte SS View Post
It's a really tight fit inside the seat. Even if the clamps were to pull away from the copper strap, the bars on the headrest would still have to go all the way through the seat cushion to do any damage. I'm sure there are other ways to secure the retainers inside the seat frame as well - maybe use short bolts with locknuts on the copper straps? I just used what I had on hand at the time, and had no issues with it while it was in my ownership.
Hope that helps!
Thanks Steve. I had success with my copper strapping and clamps as per the instructions on the site and it is lookin good!! I'm so glad and it feels strong enough as you said......cheers.
jilly44 is offline
post #20 of 21 Old 12-29-2013, 01:39 PM
iowassfan
How do you remove the plastic sleeves that the headrest slide down into? Im planning on hitting the junkyards soon if I can't find a set online.
iowassfan is offline
post #21 of 21 Old 12-29-2013, 06:33 PM
ECL
Once the donor ZJ seat is opened up, it will be obvious. There are push pin things that have to be pushed in to let the plastic pieces back out of the metal sleeves that are welded onto the frame.
ECL is offline
adding headrests to the back bench seat in an XJ? 66Satellite XJ Cherokee Technical Forum 2 12-04-2009 04:32 PM
new seats installed [writeup] fatwreck XJ Cherokee Technical Forum 10 05-11-2005 08:19 AM
Installed my Cobra 19 DX III, pics, and link to HUGE writeup in electrical section! Atl-atl XJ Cherokee Technical Forum 1 10-14-2004 12:34 AM
headrests for back seat jmg XJ Cherokee Technical Forum 2 12-30-2001 10:49 PM
rear seat headrests rferran XJ Cherokee Technical Forum 0 11-26-2001 07:51 PM
