ZJ Rear Disc Conversion to 8.25" Write Up - The Whole Truth!!! - Page 3 - JeepForum.com
post #31 of 48 Old 05-28-2009, 09:53 AM
AZ Jeff
2014 JK Wrangler
Originally Posted by alexrule123 View Post
I used the factory ZJ lines when I did my conversion and they seem to do the job just fine.
If the lines are fairly new, they can be reused straight off the ZJ donor vehicle. If they show any signs of dry cracking, replace them with new. They are not that expensive, but oh, so critical, obviously.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #32 of 48 Old 08-07-2009, 06:19 PM
multmigs
2003 WJ
did you ever install the ZJ prop valve?
multmigs is offline
post #33 of 48 Old 08-07-2009, 07:47 PM
alexrule123
alexrule123's Avatar
I did and now I have a problem where too much of the braking is in the rear
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #34 of 48 Old 11-16-2009, 03:40 PM
jjg214
to revive the best write up iv found before i start this....
is there a difference btwn the disc brakes on a ZJ dana 35 and a WJ dana 35?
WTB: HP Dana 30, Long Island/New York Area
detours backbone system for sale
jjg214 is offline
post #35 of 48 Old 11-16-2009, 03:43 PM
justanotherjpr
The bolt pattern on the rotors would be different. I don't think the calipers would be any different, but you would obviously want to use ZJ rotors.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #36 of 48 Old 11-16-2009, 04:21 PM
jjg214
ok sounds good.
jjg214 is offline
post #37 of 48 Old 11-22-2009, 12:58 AM
speed_BMW330i
Originally Posted by TPI Monte SS View Post
I used the Dorman part number; they're exactly the same specs as the ZJ studs, only they're new in a box from the auto parts store.
Yep, I figured the KJ brakes would work; my wife would have gotten pissed if I took hers though. They're tough to find in this area, so I pilfered a set from a ZJ being parted out locally. And yep, here's a pic of the Magnum wheels on my XJ -
Nice ride! What color blue is that? Is it factory or is it a custom paint job? I may look to repaint my newly purchased 1999 Jeep Cherokee and this color looks great. Hopefully that's an official Jeep color option.
Thanks
Martin
speed_BMW330i is offline
post #38 of 48 Old 12-08-2009, 06:42 AM
EzPcConcepts
Originally Posted by RckRdyXJ View Post
Good write up, Deff one of the better ZJ disc swap write ups i have read.
FYI KJ Liberty rear discs are a direct bolt on no mods required, KJs have an 8.25 with discs.
Got any pics with the magnum wheels on your XJ, I love how they look on an xja nd want a set for street wheels.
Would you happen to know if the backing plates are the same thickness? I ask because my XJ have ABS and I am concerned about the ring placement that the sensor monitors in connection to the spacing difference if there is any if I were to use a KJ setup in place of the ZJ..
Thanks
If you keep doing what you have done... you will keep getting what you got..
EzPcConcepts is offline
post #39 of 48 Old 12-08-2009, 08:25 AM
nostaw22
Thanks
Get a brakes from a doner ZJ w/ ABS and it may work... Just install your XJ sensor into the ZJ housing (or you can try the ZJ sensor -- not sure if they're the same though)... When I did the conversion I used brake components from an ABS equipped ZJ and just cut the wires off and junked the sensors (I don't have ABS).
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline
post #40 of 48 Old 12-08-2009, 04:48 PM
GregB_00XJ
I want Rear Disks for 2010.
This is a great write-up!
G
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #41 of 48 Old 03-05-2010, 05:54 PM
chuckyj95
OK I have a question will a ZJ rotor fit in to the KJ setup to keep the bolt pattern the same.
Chuck Longwell
Mohawk NY
Looking for my next jeep
2008 Triumph Speedmaster
chuckyj95 is offline
post #42 of 48 Old 03-06-2010, 01:25 AM
sprintagogo
The ZJ and KJ bolt pattern is the same, both 4.5" x 5. The WJ grand has the 'other' 5" x 5 pattern.
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline
post #43 of 48 Old 01-28-2012, 07:21 AM
RSWiser
subscribed.
RSWiser is offline
post #44 of 48 Old 01-28-2012, 09:33 AM
graytm4
1997 XJ Cherokee
Where can I get longer studs if I go ahead and do the liberty disk swap?
graytm4 is offline
post #45 of 48 Old 01-28-2012, 12:04 PM
justanotherjpr
Most auto parts stores, summit or jegs
Rear Disc Brakes on 8.25 Write-Up IntrepidXJ XJ Cherokee Technical Forum 7 05-21-2007 10:12 PM
Rear disc conversion? jeffasher1988 XJ Cherokee Technical Forum 4 11-26-2006 11:34 PM
Finished my rear disc swap, quick write up Walton99 XJ Cherokee Technical Forum 18 10-22-2004 07:48 AM
8.25 rear disc conversion - Write up AMK XJ Cherokee Technical Forum 5 08-05-2004 10:00 AM
8.25 rear disc conversion - Pics & Write up soon AMK XJ Cherokee Technical Forum 12 08-04-2004 05:15 PM
