ZJ rear disc brakes on an XJ.....
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
Will it work? I have a ZJ i am parting, it has rear disc brake and my XJ has the pesky drums. Thanks
97' ZJ 5.2 Limited- [B]Being Parted out.[/B] 88' XJ 4.0 (2wd...for now) I am N.O.R.M.L! |
#2 |
Jeeper 4 Life
what axle do you have?
'98 xj sport (trail toy) | specs '98 xj classic (dd'er) | specs '89 mj tinker toy | specs My XJ Page | My Gallery |
#3 |
some ZJs have a D44 with an aluminum center-section that will not receive some lockers. I'm not sure why, personally. I've heard of someone putting a D35 in place of an alum D44 for strength reasons. More info would be nice.
Quick test: see if a magnet will stick to the diff (not cover of course), & compare the shape to your D35 or D44. The parts may bolt up if both are D44s Interesting...Procede |
#4 |
The info is out there, but yes, it will work. I took ZJ D44a discs and put them on my C8.25 axle, they will work fine on a D35 too.
2001 Silver XJ, 4.5" Lift, 31's, SYE/DS, Gas/TC/diff skids, rails, and mud. |
#5 |
ok, my XJ is 2wd (no laughing please) I am using what i can from my ZJ and my 67' ford bronco to make my XJ off-road worthy.
I wasn't sure if i can use the whole axle assembly off the ZJ or if i had to do all the mods i read about in the FAQ.
#6 |
ZJ rear discs from a D35 will bolt up to an XJ with a D35 or 8.25. The 8.25 will require some dremmeling of the center section on the backing and mounting plates. I did it and it was worth it.
http://www.jeepforum.com/forum/f11/8-25-rear-disc-conversion-write-up-97483/ http://www.jeepforum.com/forum/f11/teraflex-rear-disc-brake-conversion-kit-181425/ http://jeepin.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=006330 http://home.swbell.net/rriojas3/reardisk.html http://cherokeekid5.tripod.com/zj_discs_on_a_xj.htm That should get you started. |
#7 |
yep it will work awesomely... and u cant use the axle assembly cause the ZJ is coil if i remeber correctly and the XJ is leaf sprung..
1990 Jeep Cherokee Laredo 4.0L Automatic Tranny NP242 Transfer case Dana 30 front, 35 custom rear differentials Mods: RE 4.5" Lift 32x11.50 BFGoodRich M/T KM's American Eagle 058 Polished Aluminum Wheels, 3.63" BS. Grand Cherokee Rear Disc Brake setup Custom Downpipe W/ Cat Removed. Dynomax Super Turbo Muffler. Surco Roof Rack My Jeep |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
