| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Consider the following...
![]() Join Date: Jan 2008
ZJ guy needs help with an Hp30
#2 |
any year below 2000 have the hp 30 not exactly sure when the change was made from disconect to non. i have a 99 and i kno that it has the 297x ujoints which are the stronger set so im guessing 96 and up have them again not 100% sure on exact year. forget the selectable locker unless u wana spend that much money, assuie lockers are simple and cheap and very good product with great street manners. i have the rough country diff skid and its held up to some pretty hard beatings, almost all aftermarket covers are similar in strength mine has served me well for a long time.
#3 |
Thanks for the info.
I want a selectable locker because this is my DD and I have the 249 transfer case which is all time 4 wheel drive. |
#4 | |
00-01 had LP30's, other than that they are all HP30's You won't find 4.56 gears on an xj, almost all of them will be 3.55 (autos) or 3.07 (manual) Chromo shafts are like any other axle, yukon, moser, etc. Selectable lockers are awesome, if you can save up to afford it, do it. If not go with an aussie, i have heard nothing bad about them. For a truss, look at Treks, i'm using their truss on my 44 and they have flawless products. U-joints you want the later model shafts and you will get the larger u-joints. Covers are all the same, you will never break an aftermarket cover. |
#5 |
swap out the 249 ASAP, you can get away with it on the street, but for a wheeling rig i would be looking for a 231 or 242 pretty soon
#6 |
Thanks for the info guys.
This is basically what I'm going for. ![]() |
#7 |
is that a D30? thats awesome im workin on my new one right now tryin to beef it up. that one looks fairly tough.
-Sean
1989 Jeep Cherokee Laredo Build |
#8 |
96 Cherokee SE 4.0 5sp 4.5" homebrew lift, Tomken + spacer & S10 leaves. P ORC SYE w/ Tom Woods Shaft 33" A/Ts, CB & Aussie locked 29sp 8.25 w/4.56's. Thrush Exhaust |
#9 | |
Tarpitz
4.88s have always been available for the hp D30, you can even get 5.13 for the lp D30 although the pinion teeth are tiny I would assume, I wouldn't run them. good luck
my Jeepspeed build thread: http://www.jeepforum.com/forum/f37/dez-racer-xj-build-367176/ |
#10 |
92+ non disco
95+ were the stronger ujoints 99- were HP So your looking for a 95-99 D30
'93 XJ Sport 4 door, 3" RC, 31" MTR's, no exhaust, no floors. Buster '92 XJ Laredo Stage 1: 4 door, 3" RC, 31" MTR's, no doors, no exhaust. Buster 2 Stage 2: Buggy in progress Full tube chassis 1.5" DOM, Insane Inline 6 engine (JP magazine), modified AW4, Atlas 10:1, titanium drive shafts, home brew 609's w/ 5.13, Ten Factory axles, locked by OX, sitting on 37" Maxxis Creepies. Oh did I mention I am going to race it? Ill have a crawl ratio of 144 and a top speed around 150mph Buster 2.1 '86 MJ 2.8l, A904, NP207, D30, D35, LWB Military Jeepers |
#11 |
The older XJ's with a 242 also were non disco axles. And some of the older 2.5 auto xj's came with 4.56's allegedly. Most 2.5's with a 5-speed have 4.10's, as did the 2.8 v6's.
Totaled-'99 Black 2 door 4 Banger 5 speed XJ DD, 3+" bastard lift w/new leaf packs, ZJ uc coils & spacer. SOLD-'98 TJ 4 banger 5 speed, 4.88's, Hp 30 ARB'd, S35 w/Detroit and truss, RK LA's, Kilby skids and LOTS of other junk. Should have kept it! Traded for my XJ - '98 ZJ was pretty and built at one time- 8.8 and 5" lift and other stuff. |
#12 |
Is a 94 XJ axle non disco? I found this for sale for $500. HP D30, 4.88’s, Alloy USA Chromos, Aussie Locker, Rock Ring, Currie LCA mount skids, sway bar mounts are cut off, 60” WMS, Drag link and tie rod that is sleeved. It's out of a 94 XJ. If it is non disco, what is the advantage/disadvantage of this?
#13 |
That's a good buy for 500! If it's a '94 it will be non disco. That's what ya want.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| 96 HP30 question | 95wrangler4life | Cherokee Technical Forum | 2 | 11-08-2009 04:40 PM |
| ABS with D44 and HP30 | Highway 4x4 | Cherokee Technical Forum | 6 | 10-30-2008 08:03 PM |
| XJ D44 and HP30 | Robbypfd | Cherokee Technical Forum | 5 | 04-08-2008 07:56 AM |
| HP30 w/ 4.10s? | Grewe02 | Cherokee Technical Forum | 14 | 02-06-2007 11:15 PM |
| Cherokee with HP30 and D44 | Tj_Justin | Cherokee Technical Forum | 4 | 10-27-2006 09:45 AM |
The time now is 09:46 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
