Yikes...Power steering fluid in brake system - JeepForum.com
post #1 of 6 Old 06-21-2009, 04:33 PM Thread Starter
XJER
I know, dumb, but I accidently put power steering fluid in the brake system. Only about 1 ounce or so, but it was driven like that for about a week and now the pedal goes nearly to the floor with reduced braking. Brake light is of course on. I flushed and bleed the entire sytem with at least 2 quarts of new brake fluid, but no improvement. I think I know I am in trouble. Is this just a M/C issue, or am I looking at hoses and caliper replacement. Idiot mistake....was in a hurry and was just topping it off before a long trip. Thanks for any advice.
XJER is offline
post #2 of 6 Old 06-21-2009, 08:40 PM
bikedude189
1993 XJ Cherokee
well, i'm guessing that if it suddenly failed, power steering fluid eats rubber... at least M/C seal rubber. pull it apart and rebuild your master, pretty cheap. take a look at your flex lines while its off, and see if any fragments come out of them. try bleeding them again, take a large syringe and pump the fluid from the calipers through to the master. this is how bicycle brakes are bled and its the easiest and best method i've found for the heep too, it pushed bubbles UP instead of down...
good luck!
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline
post #3 of 6 Old 06-21-2009, 09:45 PM
AZ Jeff
2014 JK Wrangler
good luck!
Actually, you will need to replace ALL THE RUBBER PARTS in the ENTIRE BRAKE SYSTEM, as NONE OF THEM are tolerant of power steering fluid, which is a type of OIL.
Brake fluid is a type of ALCOHOL, and thus rubber parts in brake systems are geared around being tolerant of that type of chemical.
You will need:
1. new rear wheel cylinders (or seal kits for them)
2. new front calipers (or seal kits for them)
3. a new master cylinder (or a seal kit for it)
4 new front brake hoses
5. a new rear brake hose
Finding seal kits is problematic nowadays, since no one rebuilds calipers or wheel cylinders themselves (it's more cost effective to just buy reman'd ones)
Good luck on your overhaul. I am betting you will NEVER make that simple, but critical, mistake again.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #4 of 6 Old 06-22-2009, 11:25 AM Thread Starter
XJER
Yep, that is what I thought. Guess it is a good time to hit the junk yard for some used parts and go to the stainless steel lines.....me so dumb.
Thanks for the replies.
XJER is offline
post #5 of 6 Old 06-22-2009, 12:33 PM
CharlieMopps
1989 XJ Cherokee
Rebuilt Calipers are $13 each at autozone
Rebuild the master cylinder. That kits cheap as well.
you should have extended stainless breaklines by now anyways. Go get them.
And lastly, Ford 8.8 out of a ford explorer: $200 and it has Disc breaks! (but you'll need a welder)
Ok, if you don't have a welder, get rear cylinders while you're at autozone. I dunno how much those cost.
I think this is the perfect excuse to slip an axle upgrade by the wife. "My breaks failed! It's going to cost $200 to fix. Sorry hunny!"
CharlieMopps is offline
post #6 of 6 Old 06-22-2009, 11:51 PM
bikedude189
1993 XJ Cherokee
i think you should be able to get all the seal kits and lines at q'tec. if not then scrounge your local parts stores/internets. go green! rebuild, not replace!
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
what to use for power steering fluid mud-dog27 XJ Cherokee Technical Forum 4 05-15-2009 02:25 AM
Brake fluid in the power booster Ivanito XJ Cherokee Technical Forum 1 09-20-2007 02:09 PM
Power steering fluid XJ99 XJ Cherokee Technical Forum 8 08-31-2005 09:17 PM
Power steering fluid... Gr8Swammee XJ Cherokee Technical Forum 3 05-17-2005 02:40 PM
Power Steering Fluid? djf127 XJ Cherokee Technical Forum 2 12-31-2002 11:17 PM
