Xj wont stay running - JeepForum.com
post #1 of 5 Old 03-30-2013, 06:57 PM Thread Starter
taylorbapt
I have a 99 Xj 4.0L. When I'm driving and slow down it dies and when I start it and let it idle it runs for a bit and then it's idle gets bad and jerks and dies, does anybody have any ideas what can cause this?
taylorbapt is online now
post #2 of 5 Old 03-30-2013, 07:03 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Are all the tune-up parts fresh ? The problem might be a battery issue, a failing O2 sensor, or a faulty Crankshaft Position Sensor. Start with the cheap and easy stuff. Test the sensors before you invest in any new parts.
Stalling can be caused by a low voltage issue from:
  • a failing battery
  • a failing alternator
  • dirty or loose wire connections
  • internally corroded battery wires
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Copper wires should be copper color, not black or green. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds.
CJ7-Tim is offline
post #3 of 5 Old 03-30-2013, 07:08 PM Thread Starter
taylorbapt
Thanks i will check it all and see if I can find anything bad, I've changed to O2 sensors, are crankshaft position sensors hard to change?
post #4 of 5 Old 03-30-2013, 07:23 PM
CJ7-Tim
CJ7-Tim's Avatar
Not much worse to change than O2 sensors.
CJ7-Tim is offline
post #5 of 5 Old 03-30-2013, 09:11 PM
Hudson
You need about three 6" extensions and swivel to unbolt it.
You might also need to take a few yoga classes to get your body in the right position to get to that sensor.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
